Soup Bowl...
Old Mar 4, 2004 | 06:36 PM
tazmania18235's Avatar
tazmania18235
Question Soup Bowl...
Ok I am confused here.... What excatly is are you talking about when you talk about the soup bowl???? Where is it excatly???
I purchased 85 E350 6.9 have looked around at the air cleaned and I am unsure as to what you guys are talking about ...
Thanks
Old Mar 4, 2004 | 06:48 PM
redneckmechnic's Avatar
redneckmechnic
Take yar air cleaner lid off. flip it up side dwon and ya shoulkd be looking rite at a big old upside down tin bowl welded/rivetd to the lid. Thats the soup bowl. while yar looking at it go ahead and cut it off. gives ya more power and better mpg.
Old Mar 4, 2004 | 06:51 PM
tazmania18235
As I can remember it does not exsist so I guess the pervious owner must have taken it off... I will look at again to be sure...
Thanks.
Old Mar 4, 2004 | 07:00 PM
trader rob's Avatar
trader rob
you can't miss it it looks like a derby hat, and if you can't find it you can have mine, i cut it off couple days ago.lol makes a difference sure nuff. thanks guys.
Old Mar 4, 2004 | 07:06 PM
tazmania18235
LMAO well no thank I don't want yours!!!! I know now with your comment that it is not there... Thanks for clearing that up guys...
Old Mar 5, 2004 | 05:50 AM
pnose's Avatar
pnose
Om the e series the bottom of the air cleaner has a smaller hole than the f series,cut the hole where it sits on the intake to the same size as the opening in the intake.The vans are different due to the air cleaner being a lower profile so it will fit in the limited space you have under there,thats why there is no bowl on tha lid.The bowl and/or the smaller hole are mainly there to act as a noise dampening,although they do restrict air flow.
Old Mar 5, 2004 | 06:03 AM
tazmania18235
Small hole???? Is that where there is kinda like a rubbber grommet with like a pin hole in it???
Old Mar 5, 2004 | 06:08 AM
pnose's Avatar
pnose
No,its the actual hole that sits on the intake,on f series that hole is the same size as the hole in the intake.Remove your lower section of the breather and look at the size of that hole as compared to the size of the intake hole.
Old Mar 5, 2004 | 10:06 PM
HOpowerstroke's Avatar
HOpowerstroke
I am pretty sure there wasnt a soup bowl on the 6.9 in the early 80's.
Brad
Old Mar 5, 2004 | 11:32 PM
fellro86's Avatar
fellro86
Had one on the old man's 84, still there actually, poor old thing anyway.... My 86 had the small hole in the bottom of the air cleaner base, cut it out to the size of the plenum never noticed any change in sound.......
Old Mar 7, 2004 | 06:20 PM
redneckmechnic
My 85 deffintly had a soup bowl. I say had cause the torch got the better of it.
Old Mar 7, 2004 | 10:05 PM
grtF250's Avatar
grtF250
I cut my soup bowl out a few weeks ago. so far I've noticed a some power increase and if I stay off the throttle the milage is up a lot. I was getting 15 and my last tank (just tonight) calculated out at 18. and I'm pretty sure thats still winterized fuel. Cutting it out has so far been great Wish I did it sooner.
Old Mar 8, 2004 | 06:27 AM
turbo69's Avatar
turbo69
There is a pic of the soup bowl in the 'And a few more' section of my Pics.
