Power Take-off option
Old Apr 15, 2004 | 05:04 AM
Shag's Avatar
Shag
Underhood Compressor
That is kind of pricey for my application. Besides the dealer told me anything mechanical under the hood voids the warranty. Something i can't afford to do. That was the reason for the PTO provision.
Old Apr 15, 2004 | 07:06 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
It seems a bit pricy. However if it is extremely reliable and truly needed…..not just make life a little easier then it is probably worth it.
Old Apr 15, 2004 | 07:34 AM
newforddude's Avatar
newforddude
Question. Is it worth spending the extra money even if you dont use the PTO? Perhaps the trainy is stonger and will last longer?
Old Apr 15, 2004 | 07:41 PM
1956MarkII's Avatar
1956MarkII
Yes. Somewhere in these forums was a post from someone that works in the transmission plant. He stated that, even though the order code for the tranny is the same (44E for the 4-speed auto that goes with the gas engines), any auto tranny with the PTO provision has a stronger case and internals. He said it was well worth the option price, especially if you were towing or snow-plowing.
Old Apr 15, 2004 | 08:52 PM
Casey's Avatar
Casey
I remember that post, but I think he also said that the stronger parts were only on the 4R100 with PTO. The TorqShift has the good parts in all the transmissions, PTO or not. At least that's what I remember reading...
Old May 7, 2008 | 12:52 PM
MLCRI$I$ II's Avatar
MLCRI$I$ II
Attachment 9716
Originally Posted by ****
I'm new to this place so I'm not familiar with some of the goings-on, but I've got a question. I purchase my 03 F-350 PSD crew cab with the power take off option on the torque shift. I can't find any literature on how to access the PTO. I'd like to install a compressor for my beach excursions. The manual says there is a separate book for this option, the dealer says there isn't. Anyone have any information?
Thanks,
Depends what model trans and PTO you have. I have a .pdf file of a MUNCIE 4R100 INSTALL MANUAL, but the file is too large to attach. Send me a PM with your email and I will send you the PTO info I have. If you have the 4R100 with a MUNCIE, you'll be in business.
I attemped to attach some info. Basically a brochure with some specs, but it's a start.
File Type: pdf
aaronlockhart
Jun 14, 2009 11:58 AM
BigWhiteF150
1997 - 2003 F150
Jun 16, 2008 09:00 PM
shag766
New Member Introductions
Sep 1, 2006 05:16 AM
4speedvan
Jan 8, 2005 08:09 PM
econofan
Car/truck Buying Advice
Aug 30, 2002 05:16 AM
