I'm under pressure! Or not?
I think My truck has a 8800lb gross vehicle weight. I use the truck primarily for street driving but occasionally do a bit of hauling.
I know the pressure would be less when I'm out in the mud but I was wondering what it should be for normal day driving..
Thanks!
Just an off hand guess, I would run them at 34
I'm currently running at 45. I don't know if these Xterrains are reated up to 80. I know my old stock F250 tires were but they were a different animal. I thought someone might specifically know what Xterrains were rated at.
Thanks!!
It really depends on how the tires wear or sit on the ground. Every truck and tire is different. I run 40 in my Bridgestones on my F150, but I usually have 2-300lbs in the back. You could run anywhere from 30-80. (80 would only be for Load range E while under a load). In my old chevy, I ran 26 with my 255/70/r15 on my 8" wheels.
I believe the Xterrains are 3 ply if I'm not mistaken. I'll try the tires at the pressures you suggested and see how it goes. I'll pump em back up next time I carry a ton of rocks or grass etc.. I actually use it as a truck sometimes.
Hopefully there won't be any excessvie wear as a I can't be shelling out hundreds of dollars ever other year...
Thanks for the info and if anyone has any different suggestions or comments I'd be glad to hear them.
I am running my Dunlop 315/75/16's at 25front, 20rear. They aren't wearing any different, and the ride is much nicer. Max on mine is 60psi. I think it's a federal law that the max inflation for the tire must be listed on it.
View User's Gallery Here's how I figure tire pressure:
Take the front GVWR listed on the door sticker and divide it by 2 (you have 2 tire to support either end of the truck) Take whatever number you get from that and divide it by the max weight the tires can support (printed on the sidewall by the max pressure). This should give you some decimal number. Multiply that decimal by the max pressure and that is the minimum pressure needed to properly support the GVWR of the truck. Do the same for the rear. If you seldom put heavy loads in the back you drop the rear pressure 5-10lb lower than what would be needed to support the max payload.
I got this from him on another forum asking the same type question.
So Thanks 72f150 for the info not me
Chris
