Spout connector
Old Mar 4, 2004 | 03:03 PM
smitty7's Avatar
smitty7
Spout connector
Can someone please tell me which wire going into the harness on the distributor is the spout connector. I asummed the spout connector was the harness that plugged into the distributor. Wrong!!! Back to the FTE to ask the experts. MY truck is an '85 4.9l carbed.
Old Mar 4, 2004 | 06:08 PM
ALSAIR's Avatar
ALSAIR
You should not have a spout connector with a carb. They are only on E.F.I. motors. That's why you can't find it.
Al
Old Mar 5, 2004 | 10:36 AM
sail2244's Avatar
sail2244
Yes! carbed engines do have the spout connector, But only on the TFI IV ignition. My 84 has it.
The ignition module is attached to the distributer it is that gray thing with the wires running to it. The yellow wire is the spout connector and is the only wire that has a connector in it. it is a one pin connector.
Disconnect the connector to set the initial timing.
Old Mar 5, 2004 | 01:53 PM
smitty7's Avatar
smitty7
Thanks, I appreicate the info.
