Sponsored by: Real Truck
Gears
Old Mar 4, 2004 | 09:18 AM
SUPERD250's Avatar
SUPERD250
Gears
i have a 2000 f250 superduty w/ a v 10 , how do i know what gears are in the rear end???
Old Mar 4, 2004 | 09:20 AM
johnsdiesel's Avatar
johnsdiesel
I have a sticker on my front axle that says I have 4.10. Look on your your axles and there should be a tag somewhere.
Old Mar 4, 2004 | 09:25 AM
SUPERD250's Avatar
SUPERD250
good deal ill check it out!!
Old Mar 4, 2004 | 09:26 AM
Big Orn's Avatar
Big Orn
On the door tag (on the door frame) there will be a space under "AXLE" with a number like 61 or an alpha/number like B5.
On the rear axle there should be a tag that tells you the size.
More than likely a Ford 10.50"
There's alot of info in the Sticky at the top of this page.
Old Mar 4, 2004 | 09:28 AM
n578md's Avatar
n578md
Or you can look at the sticker on the door jamb under "AXLE". Two numbers is an open diff, a letter and a number is a limited slip. The second character tells you the ratio. 1 is 3.73, 2 is 4.20, 3 is 4.30 so for ecample a C1 is a limited slip 3.73 and a 33 is an open diff 4.30. There are two tags on the right side of your rear diff, one is the oil weight requirement and the other is the axle ID tag. It read something like this:
3V 435H
3 L 73 10 5 3E06
Yours will probably have a 3S in the first position (Plant code in this case Sterling Heigths Michigan axle plant.)
The 435H is the axle model and revision.
The third item is your ratio. 3 73 is 3.73 obviously but there will be an L there if your axle is a limited slip. Without the L, it's an open diff.
The 4th item is the ring gear diameter, 10.5". The 5th item is the axle's build date, 3E06 means May 6th 2003. If your axle was made say March 24 2000, your code would be 0C24. Comprende?
NDFordman
Mar 16, 2016 06:42 PM
MechaNick702
Apr 28, 2014 09:08 AM
delifresh
Oct 29, 2013 04:07 PM
ukjellybelly
Jul 30, 2013 08:41 PM
jbhf250
Apr 1, 2000 08:25 PM
