1978 - 1996 Big Bronco
Stupid but bothersome
Old Mar 4, 2004 | 02:41 AM
BiggerThanBlazer's Avatar
BiggerThanBlazer
Unhappy Stupid but bothersome
Okay, so yeah, this isn't the most high tech or important question, but the switch to role up and down the tailgate window half works. What I mean by this, is that it will roll it down no problem, but not back up, I have to get out and use the key. It's not that serious of a problem obviously, but it's one of those that bugs you. I have taken the switch apart and sanded the contacts to clear grime or anything, it actually made the down button better but not the up. I have only gotten it to go up like an inch that was twice, both times within like two seconds of eachother. So I am pretty sure it's not the wires. I am thinking of taking a volt-meter to the plug to make sure all wires have running power, and buying/getting a new switch to see if that will help at all. Anyone had this problem before, or any suggestions?
~Sam
Old Mar 4, 2004 | 02:53 AM
NJbronco138's Avatar
NJbronco138
I had the same problem. I would have to hold down the switch as hard as possible for teh chance it would roll the window up. I cleaned the switch too and it didnt' help. I bought a new switch from Ford it was maybe 25 bucks hooked it up problem solved
Old Mar 4, 2004 | 04:31 AM
Kingersj's Avatar
Kingersj
I agree completely, that was the first thing I bought for my bronco. what you will hate is the fact that it will take you less time to replace it then it did to clean and sand all of those contacts.
Old Mar 4, 2004 | 09:13 AM
BillyBob69's Avatar
BillyBob69
Umm Did anyoe mention the SWITCH!!! hehe
Old Mar 4, 2004 | 09:35 AM
Griffkay's Avatar
Griffkay
My problem is the opposite my switch works fine but i can't lower the window from the key it's annoying but i can deal with it.
Old Mar 4, 2004 | 10:13 AM
BillyBob69's Avatar
BillyBob69
Griffkay...take the key switch out and clean it...or you could find you need another switch.
Old Mar 4, 2004 | 10:45 AM
BiggerThanBlazer
Hey, thanks a lot guys, I just got my Bronco, and it's kinda bothering me, considering that everything else works.
Old Mar 4, 2004 | 07:41 PM
Griffkay's Avatar
Griffkay
Kool i am gona try that. thanks
