97 PSD dies
Old Mar 3, 2004 | 06:40 PM
Dustin_86's Avatar
Dustin_86
97 PSD dies
I haVE a questin about my friends moms stock 97 F350 SRW PSD cew cab Manual trans. 200K miles She drove it "all day" and drove in the drive way and it just "died" will turn over but will not restart! New wix fuel filterthat I personaly put on! ans still nothing. Oh wait 6 hrs later it fired up!! yah!!!!!!!!! I drove it for 15 minutes and it shut down(like i just turned off the key) .
Later
dustin
Old Mar 3, 2004 | 07:16 PM
believer45's Avatar
believer45
When cranking it in the "no start" situation does the tach register any RPM? If not, you probably have a Cam Position Sensor on its way out.
Common failure.
Dave / Believer45
Old Mar 3, 2004 | 08:32 PM
78fordman's Avatar
78fordman
My tach on my 00 PSD does not register anything when cranking and my CPS is fine, or does it onyl apply for older PSD's?
Old Mar 3, 2004 | 09:07 PM
F0rdF0rever's Avatar
F0rdF0rever
Mine is the same fordman...
Old Mar 4, 2004 | 07:11 AM
powerstroker250's Avatar
powerstroker250
Mine too. No tach movement until the engine actually fires. Sounds like the cps to me also.
Old Mar 4, 2004 | 01:55 PM
Biwanylo's Avatar
Biwanylo
My Tach. will show 300 to 400 rpm when starting. 97 HD PSD 4X4
Old Mar 4, 2004 | 06:06 PM
78fordman's Avatar
78fordman
I would say take a fuel pressure test if you can on these PSD's, i'm pretty sure you can.
klatt_89
Jan 25, 2006 04:18 PM
Dustin_86
Car/truck Buying Advice
Aug 17, 2005 07:28 PM
Dustin_86
Jun 4, 2004 09:36 PM
Dustin_86
May 15, 2004 11:08 PM
Dustin_86
Paint & Bodywork
Mar 9, 2004 09:08 AM
