Bronco II Ford Bronco II
Help!!! like a frog
Old Mar 3, 2004 | 11:46 AM
bizarro's Avatar
bizarro
Unhappy Help!!! like a frog
I need your help!...
Bronco II 1989, manual 2WD
When I turn on the car I need to turn on like 6 times because the motor turn off, once I start it if I press the gas pedal the motor turn off, I need to start it several times to warm the motor. When I turn on the first 3 times it seems like the gasoline does not arrive to the motor. When the motor is warm (like 6 minutes later of turn on 6 times) and when I press gas, the motor don't respond fast, like 2seconds later the car respond normally, every time I stop it's the same thing (like a frog).
I need to clean the injector's? or change the fuel pump?
what you think I need to do?
Lately (3 weeks ago) I change the fuel filter, sparks plugs and wires
Old Mar 3, 2004 | 01:21 PM
Ken00's Avatar
Ken00
I would test the fuel pressure, should be 35-45, before replacing anything.
Old Mar 3, 2004 | 05:03 PM
bizarro's Avatar
bizarro
Thanks...
but, I found one spark plug with oil, you think that the oil is the root problem, or the oil is another problem?
thanks friends...
Old Mar 3, 2004 | 05:12 PM
mrshorty's Avatar
mrshorty
Did you check all 6 plugs and find one fouled with oil? or did you check one plug and found it fouled? Oil fouling spark plugs would certainly cause rough running. Find out why you are getting oil into the cylinders (bad piston rings or bad valve seals or what)
Old Mar 3, 2004 | 06:05 PM
bizarro's Avatar
bizarro
I check the 6 spark plug and find one with oil.
I don't now were come the oil, the car has power, the problem is wen the motor is cold and I turn on the motor.
wen the motor is warm the car run great, until one stop but on freeway the car run fine.
thanks
Old Mar 3, 2004 | 06:44 PM
Ken00's Avatar
Ken00
I think its a different issue, run a compression test to start.
Raidy
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
24
Feb 20, 2014 08:39 PM
Bunny and Frog
Mar 4, 2012 07:46 AM
datchew
92
Dec 20, 2005 03:34 PM
datchew
Dec 15, 2005 08:14 AM
frog
Jul 15, 1999 04:00 PM
