Yes, I know this topic has been discussed before but I'm taking a different angle this time.
I want to lower the front and rear of mine only an inch to an inch and a half. I feel if I lower the front 2 inches or more the wheel will rub the plastic inner fender liner on full compression. Of course I could remove the plastic but then I'll get the rocks flying off of the tires and making lots of noise.
So I guess I'm asking if I can use say a 6cyl coil up front or cut an inch out of mine (with a chop saw, not a torch) without it affecting caster/camber or ride significantly. I know in the rear I can remove a leaf or two which would lower towing capacity but I do not tow very often.
Also does anyone know if the spring must be removed to get the bracket for the sway bar off/on? A friends truck got wrecked and it has a factory front sway bar that I can have. It looks like mine has the bracket for it but I can't quite tell how it hooks up, any info would be appreciated.
Nick
If you remove two springs in the back I am afraid you will find your self yawing down the road like a boat with no rudder. You can get a 2" drop in the back with shackles or make your own for a 1" drop.
Thats kinda what I figured, the back isn't as big of a deal to lower as the front, lots of room back there. Yours is lowered pretty drastically in the front, more than an inch if I remember what you've said in other posts, what size wheel/tire do you run (how tall is it also) and do they rub anything under compression or full lock to lock turning?
Nick
I've got the 3" drop "I" beams and I think the coil probably has sunk a little over the years. I'll be replacing the spring. 235r6015 don't hit but it's close.
