Engine has trouble idleing down
Old Mar 3, 2004 | 06:00 AM
gunner9821's Avatar
gunner9821
I have a 1994 F-150 w/302 mpi. After I reach speed I can let off the gas and it will hold the same rpm for a period of time, sometimes even when stopped. If it was carb. vehicle I would assume that the choke is sticking, it acts the same way. I have replaced the dist. cap, rotor, plugs, and the clock spring for general tune-up reasons, and it still remains the same. Any suggestions.... is there some sort of relay that controls this ???
Old Mar 3, 2004 | 06:57 AM
EPNCSU2006's Avatar
EPNCSU2006
The idle air control valve can get dirty and stick open. It is the thing on the side of the throttle body. Take it off and clean it out, and see if that helps.
Old Mar 3, 2004 | 07:48 AM
deananthony's Avatar
deananthony
I agree with EPN, I was having similar problems and replaced the IAC with 100% success, problem solved for 52 dollars
