Sponsored by: Auxito
power mirrors not working right
Old Mar 2, 2004 | 08:57 PM
BrilloDuck11's Avatar
BrilloDuck11
i have a 2002 f-150 and my power mirrors arent working right. for example if i try to move them up or down, they go at a diagonal and it takes like 5 min to do something that should take about 1 sec. its like this on both sides, i am getting ready to take it in and have it looked at, but just thought i would see if anyone has had this happen, and if so how they delt with it.
Old Mar 3, 2004 | 12:20 AM
czechyour6's Avatar
czechyour6
I just replaced the switch on my 97 and it worked great and only 20.00 a dealership part. But mine was not moving slow, just would not adjust to the Right on either mirror. Good luck!
Old Mar 3, 2004 | 06:14 PM
Keith1984's Avatar
Keith1984
Hmm, not adjusting to right. Same issue with mine. Whole door panel need to be removed or does that little panel just pop up?
Old Mar 3, 2004 | 06:19 PM
sty's Avatar
sty
door panel
Hello all! The door panel removes with 2 screws . One is behind the garnish around the inner handle ,(soap dish) the other under the sail on the outer edge of the door , remove this and remove the screw. Lift and pull up to remove the panel. The bezel is the piece that the switch is in. It pops up and off , from the front.
Good luck
Sty
Old Mar 3, 2004 | 08:44 PM
superrangerman2002's Avatar
superrangerman2002
I am also haveing the same troubles with my power mirrors, on both sides, just as Brillo described.
I took the bezel apart and monkey with the connections, now it seems to be working intermittantly.
They almost act as if they are now recieving enough pwr to move in one direction.
I think that it is also the switch, and this weekend I plan on replacing it.
Old Mar 3, 2004 | 08:49 PM
Keith1984's Avatar
Keith1984
I wonder if the switch itself can be repaired. Maybe a shot of contact cleaner.
Old Mar 3, 2004 | 08:55 PM
superrangerman2002
Maybe, but the thing is so easy to replace, and small any way...
Is it worth it....I dunno.
