Distributor / Coil Recomendations
Old Mar 2, 2004 | 07:48 PM
mechanicsburg's Avatar
mechanicsburg
Question Distributor / Coil Recomendations
I have a 1966 SWB stepside with 352 3 speed. I will be installing Edelbrock Performer 390 Intake and 4 bbl carb and am considering a mild performance cam. Headers are also in the picture.
My question is that I suppose I should replace the stock distributor, but there are so many types in the catalogues. Many costing several hundred dollars. I don't want to install anything rediculous or that I won't utilize, but I want something modern, efficient and reliable. What are the recommendations? This will just be a driver.
Old Mar 2, 2004 | 09:04 PM
fixn66's Avatar
fixn66
I dont really know what your looking to spend.But I also have a 352 with a Edelbrock Performer intake and 4 bbl Carb.I just purchased a Mallory electronic distributor along with a Mallory coil.Cost me around $375.00.Hope that might help you.
Old Mar 2, 2004 | 09:26 PM
BobbyFord's Avatar
BobbyFord
An inexpensive way to go is a Pertronix unit that replaces the points and condenser and utilizes the stock coil. About $80.00
Old Mar 3, 2004 | 07:53 AM
FERacing66's Avatar
FERacing66
id go with the petronix as well, you keep the orgianal look of the motor if that matters and its cheap compared to buying an electroic ignion.
Old Mar 3, 2004 | 10:25 AM
Mike G's Avatar
Mike G
Or you can get a 75/76 Duraspark distributor from the local autoparts store for about $65, make a trip to the salvage yard for the wiring and brainbox and go from there (search the site for Duraspark upgrades).
--Mike G
Old Mar 3, 2004 | 11:52 AM
Roger Carter's Avatar
Roger Carter
I agree with Mike G, if original appearance is not important. Otherwise, the Pertronix is the way to go. The Duraspark is a good choice for a mild FE motor. I like to use a MSD 6A in place of the Duraspark brain box though. The MSD has very good wiring diagrams and makes the install a snap. The Duraspark / MSD combination is what I use on my rigs.
Which ever way you decide on make sure the distributor is in good condition, or you will not get full benefit of the dollars spent. A re-curve is always a good idea, also. Typically you would want all the advance in by about 3,000 rpm.
Hope this helps.
Roger Carter
Old Mar 3, 2004 | 05:25 PM
mechanicsburg
Thanks for all the advice. I'll do some research into the suggestions offered here.
M
richardfine
Feb 12, 2017 09:02 AM
Sportsterengr
17
Apr 7, 2016 09:08 PM
Gigemags05
Feb 19, 2015 09:20 PM
pitbulls20
Feb 4, 2008 08:31 PM
jwgeorge
Sep 20, 2005 09:52 PM
