Sponsored by: Auxito
tranny troubles
Old Mar 2, 2004 | 05:31 PM
hdbadpig's Avatar
hdbadpig
tranny troubles
I'm new to the forum and already solved two problems by reading some of the posts. My 99 f150,4X4 w/5.4 auto was having trouble between first and second during normal driving. Transmission shop replaced "an actuator spring" today then decided to keep it after roadtesting it. Said they ordered a new valve. Truck is still under used dealer warranty. Anything I should be aware of?
Old Mar 2, 2004 | 09:33 PM
F2504x4's Avatar
F2504x4
try disconnecting the battery, for 10-15min.s then drive the truck,
Old Mar 2, 2004 | 10:22 PM
Racerguy's Avatar
Racerguy
What are the symptoms of what it was doing?
Old Mar 3, 2004 | 05:27 PM
hdbadpig's Avatar
hdbadpig
As for the initial problem, the tranny was hesitating prior to entering second gear then would enter with a distinct kick. If you babied the accelerator the problem was minimal or non-existent. I just got the truck back from the tranny shop. The transition from first to second is markedly better, but not complete and now there is a kick as it re-enters first from second. Supposedly they replaced some type of valve. Have to call in the AM to tell them it's not right and make a new appt.
Kim Ouyang
1997 - 2003 F150
Jul 6, 2012 05:43 PM
drh1175
6.4L Power Stroke Diesel
32
Jul 16, 2010 07:05 AM
vloney
22
Dec 3, 2007 11:24 PM
19903024x4
Aug 20, 2007 05:06 PM
