84 Ford F150 4X4
I'm able to start my truck when it is cold. Then when the truck is warmed up, it doesn't want to start anymore (crank over). The battery and altenator checks out good. Something seemed to be smoking under the hood right in front of the drivers side (I'm not sure if this is relevant to the issue since it was having the same problem prior to smoking).
Please assist since this is the first time owning a truck and I'm on the low end of knowledge right now.
