Sponsored by: Innova
2003 Upgrades!
Old Mar 2, 2004 | 12:51 AM
Smokem''s Avatar
Smokem'
2003 Upgrades!
Not much for posting on this audio stuff, but there's only so long a mobile dj can go without a rad system in the truck too.
So far i have got a pioneer 6500dvd for a head unit. I am thinking of either going with poineer or infinity perfect 4x6's all around.
if that's ok, good,
Here's the trouble, i have to use my backseat(extended cab),not very often but there are times i need it all back there. So i'd like an easily removable box.
I figured if i went with a pair of 10's or 12's in seperate boxes behind each seat. I dunno what brand or what amp.
HELP, i need to know, I aint looking to rumble the neighbors outta bed, but i want the cab to sound good. It aint gotta rattle, but sound very well when turned up in the summer time.
Old Mar 2, 2004 | 10:29 AM
smokey6309028's Avatar
smokey6309028
I'd recommend Image Dynamics IDQ subs. They have a fairly shallow mounting depth, they are an excellent sound quality sub with plenty of punch.
Old Mar 2, 2004 | 02:42 PM
brianas's Avatar
brianas
hows it going--I would recommend a single 12" woofer in a sealed
enclosure-- You will get plenty of quality sound out of a single woofer--as it will be placed right behind the front seat it will be heard and felt---Id shop around on brands--just get good brand name equipment that you like
You can take the top of the back seat out easily - and mount a amplifier back there for your woofer-- theres also plenty of room
if your 6500 has a brain that needs to be seperatley mounted
then you will have a fairly small-compact box - easy to remove
g/l
Old Mar 2, 2004 | 11:59 PM
Smokem''s Avatar
Smokem'
is there any real difference in the sound/ performance of 10's and 12's I found a good deal on some subs that'll prolly work but iwas wandering, they're jl brand.
Old Mar 3, 2004 | 07:08 AM
brianas's Avatar
brianas
the larger diameter (surface area)of a sub will allow it to displace more volume
which equates to greater sound pressure levels SPL
and also the larger sub will generate the lower bass notes
a little easier and more pronounced
however on the sound quality side of things--you can get great sound out of most any size sub woofer in the correct setup
if your going with a single sub a 12" would be best
if going with 2 10" you will also be very happy
just make sure you use the right enclosure for those subs
g/l
Billy Bob Jo
Car/truck Buying Advice
Mar 25, 2012 06:47 PM
oddshot
15
Aug 7, 2010 08:10 PM
BigMike74
New Member Introductions
Apr 30, 2007 09:05 PM
truckfarmingcanuck
Ontario Chapter
Sep 9, 2005 12:52 PM
66f14evr
Alberta Chapter
Dec 30, 2004 10:49 PM
