86 f150 trans ????
Old Mar 1, 2004 | 09:39 PM
BIG BRD's Avatar
BIG BRD
86 f150 trans ????
a friend of mine owns a 86 f150 2wd w/4.9 straight 6 with a 3spd w/ od manual trans. basically he needs a new trans cause the one he has just took a dump. he is wanting to keep it as a manual trans and is wondering what is interchangable with his particular vehicle. ie 5spd or heck maybe a 6spd j/k any information on what will fit or where the best place is that he can buy one from would be great. thanx in advanced. leroy
Old Mar 1, 2004 | 10:07 PM
Redneck-Cowboy's Avatar
Redneck-Cowboy
Mazda 5 spds are junk if you are gonna pull anything, the T-18 is a tough 4 spd tranny, but it's not a "highway" tranny, there is a 3spd with a overdrive(4th) to be found, I'm not sure what that is though.
Old Mar 1, 2004 | 11:41 PM
MontanaFord's Avatar
MontanaFord
from what i'm told, you can get what i've been told is called a ZF tranny, it's basically a T-18 with an extra OD gear, so you keep your granny, and add a highway gear...i'm told it ain't a cheap tranny, tho...
MontanaFord
Old Mar 2, 2004 | 09:25 PM
Redneck-Cowboy
That must be what my uncle has in his 94 F-250 4x4, it still has granny low like mine, but it has an overdrive.
Old Mar 2, 2004 | 09:52 PM
BIG BRD's Avatar
BIG BRD
thanx guys for the info, ill let him make his decision or do his own research. thanx again. leroy
Old Mar 2, 2004 | 10:23 PM
Robert Red Ford's Avatar
Robert Red Ford
you can always go with the good ole np245 3 1/2 speed granny gear tranny, they are tough as nails
Old Mar 5, 2004 | 07:19 PM
RazzMaTazz's Avatar
RazzMaTazz
Big Bird,
I just swapped my NP435,3 speed w granny trans to a srod, it has 1st thru 3rd plus od. Your friend probably had this tranny.
I had to get the matching drive shaft and got lucky that my crossmember could be turned around and lined up to the new tranny.
Also I had to change the speedo gear from 19 tooth to 16 tooth to get it to register correct.
Hope this helps,Mark.
Old Mar 16, 2004 | 11:54 PM
hotwheel's Avatar
hotwheel
Originally posted by RazzMaTazz
Big Bird,
RAZZ,
I'm thinking about putting the srod into my Unibody pickup with a 390 engine. Is it strong enough for a daily driver that is occaisonally used to tow a trailer? did you have any Bellhousing our clutch spline problems?
Thanks,
Reggie
Old Mar 17, 2004 | 08:28 PM
RazzMaTazz's Avatar
RazzMaTazz
Lightbulb tranny swap
Hotwheel,
I think the tranny would do OK if the trailer wasn't too big and the 390 was close to stock.
If you had a np435 then the bellhouseing should be the same.
I don't know about the clutch splines as to the #'s ,on mine it was the same. As far as it goes I'm lovin it , My in town gas milage is the same, but haven't taken a long trip to check hiway yet.
The srod is a lighter trans ,aluminum case instead of cast iron of np435. The srod was about 2" shorter so I had to put in a longer driveshaft.All I could find in junkyards were 2 peice,so when weather warms a little more I'll pull it and have a single 1 made in winston salem.
PS are you in NC?
Old Mar 18, 2004 | 10:40 PM
hotwheel's Avatar
hotwheel
Re: tranny swap
PS are you in NC?
Thanks for the Info RAZZ......I'm located in Texas.
