Why aren't all AMSOIL motor oils API licensed?Answer..
Even after reading this long Amsoil article I'm still staying with Mobil 1 but I now know why they don't have the API licensing.
Most likely has been on the board many times before but I never read it so others also may not have.
Due to the forum's character limit I have to post twice.
AMSOIL API Licensing
Q. Why aren't all AMSOIL motor oils API licensed
A. Good question. AMSOIL staffers have recently read some message boards with misinformation regarding this issue. Let us address API licensing in depth, as well as the issue of warranties. Some AMSOIL motor oils are API licensed, some are not. If you're concerned about your warranty and feel pressures to use an API licensed oil, even after reading this answer, then the 5W-30 (XLF) or 10W-30 (XLT) XL-7500 or our 15W-40 (PCO) API licensed oils should be your choice. If you are looking for an alternative to frequent oil changes or just want the best performing oil for your car, then one of our top tier non-API licensed synthetic oils are for you. Read on, and decide for yourself.
API Licensing - Passenger Cars - What is it?
An API (American Petroleum Institute) license indicates that a specific motor oil formulation has passed the minimum performance standards as defined by a series of laboratory bench, physical, chemical and engine tests. These tests were selected and minimum performance standards were set by the API Lubricants Committee to address specific areas such as engine wear, deposits, fuel economy, emissions, etc. The committee is comprised of representatives from automobile, oil and additive companies. The current specification is SJ/GF-2, and in July 2001 the first use of SL/GF-3 will begin.
Costs
The cost for running a test program for a single passenger car motor oil formulation is from $125,000 to $300,000, depending on if the formula passes the tests the first time through or requires multiple test runs or formula modifications to achieve a passing average. (That amount goes to $275,000 to $500,000 for a Heavy Duty Diesel licensing program on a specific formula.) Once that testing is complete and the formula has passed all of the minimum requirements, it can be licensed for $825 per year for non-members and $625 per year for members. There is also a small royalty fee per gallon sold for all gallons over one million. The length of time between new specifications is now approximately 2 to 3 years, which does not allow a great deal of time to recover testing costs.
Who Licenses What Formulas?
Additive companies, such as Lubrizol, Ethyl,, Infinium and Oronite, develop licensed formulas that they offer to oil companies to re-license. It is inexpensive to re-license one of these formulas, and the majority of oil companies choose to do this to avoid the costs associated with testing. This, however, tends to commoditize the market. The same chemistry is being sold under many brand names. Most of the major oil companies do have their own proprietary formulas developed, tested and licensed. All of AMSOIL INC.'s lubricant formulas are unique and proprietary.
Flexibility In Manufacturing An API Licensed Formula
API licensing was originally developed for mineral based oils, and it affords these oils more flexibility than synthetic oils.
Mineral oils comprised of group I and Group II petroleum basestocks may use a simple program called basestock interchange for added flexibility in manufacturing and purchasing. Interchange means that by completing the proper paperwork and running a few minor engine tests an oil company can choose to buy these petroleum basestocks from many different suppliers. This ensures adequate supply and competitive pricing. However, basestock interchange for Group III and V synthetic basestocks is not allowed. For example, if a formula was tested with an ester (Group V) basestock from a specific supplier, then anyone blending that formula must buy only that supplier's ester. Complete engine testing would need to be performed on the formula using another supplier's ester before an oil company could buy it from that alternative supplier. This additional testing is normally not performed because of the associated costs. This inflexibility makes it very difficult for synthetic lubricant manufacturers to negotiate prices with synthetic basestock suppliers. There is also something called viscosity grade read-across. Fortunately, this applies to both petroleum and synthetic basestocks although the better cold temperature performance of synthetics makes it more difficult to achieve in some situations. (That's another whole story.) What this means is that if you properly formulate the lubricant for which you have run all of the API tests, there are guidelines that allow you to use that same formula to make 0W-30, 5W-30, 10W-30, etc. viscosity motor oil.
Finally, there is a rule for substitutions in the CMA (Chemical Manufacturers Association) code of practice that allows a small degree of flexibility for all formulas. It allows a company to change the percentages of components in the formula by varying amounts from the original formula with limited testing and paperwork requirements. For example, if the licensed formula used 10% of a certain V.I. improver, you would have the ability to utilize from 9% to 11% of the same V.I. improver for your formula.
Key Limitations For API Licensed Formulas
Phosphorous content - .10% maximum
(API SL; 0W-20, 5W-20, 0W-30, 5W-30, 10W-30 viscosity grades, only)
NOACK volatility - 15% maximum
The prevalent sources of phosphorous in motor oils are additives called zinc dithiophosphates (ZDTPs). Currently, these versatile additives act as oxidation/corrosion inhibitors and aid in the ability of a lubricant to reduce wear. The automobile manufacturers, however, have demanded that lubricants contain a maximum of only .10% phosphorous. Their reason is that some manufacturers believe that higher phosphorous content levels will poison the catalytic converters on their cars before they reach 150,000 miles, which is the number of miles that their vehicles will be required to pass EPA emission standards. There has not been total agreement within the automotive and lubrication industry about whether phosphorous levels over .10% actually do harm catalytic converters in the long run. What they have failed to make allowances for is the NOACK volatility of an oil.
The maximum allowable NOACK volatility percentage for the new SL/GF-3 passenger car motor oil specification is 15%. Most of AMSOIL motor oils are in the 5% to 8% NOACK volatility range. Studies have shown there is a correlation between NOACK volatility, oil consumption and the amount of phosphorous from motor oil that will end up in the exhaust gasses. Therefore, oils with higher levels of phosphorous but with low volatility, such as AMSOIL motor oils, present no more risk to catalytic converters than low phosphorous oils with higher NOACK volatility. This has also been demonstrated for years in actual application through state mandated exhaust gas testing on our Dealers' and customers' high mileage vehicles using AMSOIL synthetic motor oils. State inspectors are continually amazed at the low emissions levels generated by vehicles using AMSOIL products. So much for poisoning catalytic converters.
AMSOIL INC. has determined that the reduced wear and extended drain intervals achievable with phosphorous levels higher than the API limit of .10% are real benefits for the consumer, and pose no risk to catalytic converters. AMSOIL motor oils, except for the API licensed XL-7500 5W-30 and 10W-30 viscosity grades, all have greater than .10% phosphorous levels, and therefore, cannot be API licensed.
Why Some AMSOIL Synthetic Motor Oils Are API Licensed And Some Are Not
1. Full API licensing puts AMSOIL INC. in an inflexible position. Not only would we find it necessary to buy formula components from specific vendors and be at the mercy of their pricing, we would not be able to make any major improvements to the lubricant formulas for 2 to 3 years, without new testing and the associated costs. To solve this problem, the API must establish basestock interchange guidelines for synthetic basestocks just as they have for other basestocks, as well as develop interchange guidelines for other components too.
2. Full API licensing would impose strict phosphorous limitations on our motor oils. This limitation is the main reason most AMSOIL motor oils are not API licensed. AMSOIL INC. currently disagrees with this limitation and feels strongly that the reduced wear and longer oil and additive life achieved through higher levels of properly balanced phosphorous content is more important than the arbitrary API phosphorous limit that does not give any consideration to the NOACK volatility level of an oil. When chemistry is developed that will provide superior engine wear protection with reduced phosphorous levels, or Noack volatility considerations are put in place, then the phosphorous level will become a non-issue.
Fortunately, the law does not allow manufacturers to "void your warranty" simply because of the brand of oil you use, the specifications it meets or the miles you drive between oil changes. To be specific, they cannot deny to fix your broken radio, faulty valve or cracked piston because you used an AMSOIL non-API licensed motor oil, or because you've gone more than 3000 miles since your last oil change. Denial of warranty coverage must be specifically due to an oil related failure. All courts of law will find against any manufacturer or dealership that tries these warranty shenanigans. If any automobile dealership insinuates that your warranty will be void if you use AMSOIL products or utilize extended drain intervals, let AMSOIL INC. know the name of the Dealership, the address, the owner's name and the name of the employee that made this statement. Mail to:
AMSOIL INC.
Attention: Technical Services Department
AMSOIL Building
Superior, WI 54880
or e-mail to tech@amsoil.com.
They will almost never put it in writing, but if they do, please send us a copy of that, too. Either way, we will send them a letter informing them cease the intimidation of our customers.
Only if the oil is determined to be the direct cause of the engine problem can a manufacturer or dealership deny warranty coverage for that specific problem. In this situation the AMSOIL warranty would apply, and the AMSOIL Technical Services Department would assist you in processing your claim and in getting the vehicle repaired. That's our pledge to you. AMSOIL INC. sells millions of gallons of oil per year and warranty claims are a rare occurrence. If you ever have a warranty problem with an automobile manufacturer or dealership, AMSOIL will assist you by analyzing the problem and providing data supporting the fact that repairs should be made under the vehicle manufacturer's warranty. If this does not resolve the problem, AMSOIL will submit a claim with our insurance company and request that an adjuster have the vehicle repaired and pursue legal settlement later if necessary. The fact is there never has been an engine failure attributed to the non-performance of AMSOIL products, and we do not expect there ever will be. If it ever did, both AMSOIL and our insurance company would make certain your problem was resolved. How Does AMSOIL INC. Ensure Their Products Meet Or Exceed The Minimum Specifications Of The Tests Required For API Licensing?
First, AMSOIL INC. works closely with major additive companies to select the top performing, and usually most expensive, passenger car and heavy duty diesel motor oil additives. These additives have already passed all of the API licensing requirements in a petroleum or synthetic based formulation. Then we work with the additive company to maximize the amount of additive used and to boost the additive package in selected performance areas to achieve an optimum performing additive package for reduced wear and extended drain intervals. This is unlike the vast majority of companies who, because additives are expensive, use the minimum amount of the least expensive additives required to meet the minimum API requirements.
We then utilize a blend of synthetic basestocks with known performance characteristics as a replacement for the petroleum basestocks to optimize performance in areas of lubricity, volatility, viscosity index, oxidation and nitration resistance, pour points, flash points, deposit control, soot handling, emissions, etc. We also will utilize a highly shear stable V.I. improver to ensure viscosity retention throughout extended drain intervals. This replaces the inexpensive and less shear stable V.I. improver used in the API licensed petroleum formula. We do laboratory bench tests before running field tests to verify the superiority of the synthetic formula in actual use. We also continue to monitor the performance of the oil through close scrutiny of tens of thousands of oil analysis tests per year across a wide variety of vehicles all around North America and the World. AMSOIL INC. has been collecting used synthetic oil samples from passenger cars since 1982. No other oil company has such a vast data base of the performance of synthetic lubricants over extended drain intervals.
AMSOIL INC.'s products and formulations outperform API licensed oils. They're engineered that way. Period.
Conclusion
AMSOIL INC. takes pride in never having conformed to industry norms or standards when those standards are contrary to peak performance. We introduced synthetics to the automotive world in 1972 with the first synthetic motor oil to exceed API performance specifications. At that time other manufacturers refused to recognize the superior performance of synthetic motor oils. Now, however, most companies sell synthetic lubricants, vehicles are factory filled with synthetic motor oils and gear lubes, and some manufacturers even offer extended warranties if you use synthetics. AMSOIL has always offered extended drain intervals because the oil was capable of performing for extended drains, and it was the right thing to do for the consumer. Now the entire industry is moving in that direction. Ironically, it was recently published that automotive manufacturers will be recommending extended drain intervals of up to 15,000 miles in the near future because that's what consumers want.
AMSOIL is a company of firsts. That doesn't happen by always conforming to industry norms and standards.
API licensing of lubricants is voluntary, and it ensures automobile manufacturers and consumers that the product meets a set of minimum standards. Should these standards, in the future, be raised to a level consistent with AMSOIL's standards for motor oil performance, AMSOIL will consider licensing all oils. For those that feel pressured to use an API licensed product, we have them and encourage you to use them (XLT, XLF and PCO). AMSOIL does offer better performing motor oils that are not API licensed for all of the reasons explained in this response. They provide our customers with alternatives to the commodity products typically available in the market today. If you want the convenience of extended drain intervals or the top performance from your vehicle, AMSOIL has taken time to engineer the very best money can buy.
The monetary excuses for the lack of API licensing on some of their product line are weak. The fact that they feel is not worth it nor would they recoup the expenditure for API testing is not believable. This is not bargain oil it sells for a premium price and the cost of testing should not be an issue.
it has to do more with marketing, it is hardly the same. Billy Joe Bob can't sell Mobil-1 out of his garage and make a Mobil-1 website with ridiculous claims, etc.
Edit: As an example to how meaningless API is, SF-SJ has a Sequence IIIF oxidation test with a limit of 375% viscosity increase after 60hrs! SL has a limit of 275% at 80hrs. Red Line oil tested at 15% in the SF-SJ test!! And I believe Amsoil more recently also tested one of their oils and blew away the specs. Same for M1 a while back.
The fact remains that no matter how loose the API requirements may be they serve as a measure of insuring that the oil we buy is acceptable for our applications. It is the standard of the automotive industry. The claims on certification not being worth the cost or to costly are ridiculous. Amsoil sells oil as a secondary product their primary product is BS.
1) The API licensing program has ONLY been in place since 1992. I find it hard to believe that the motorcar existed for approx 100 years before donuts starting appearing on oil containers. My parents and grandparents must have been very brave indeed to venture beyond their respective driveways without an oil blessed by the API.
2) The API "Certified for gas engines" program is even newer and appeared sometime in the mid 1990's. The intent of this program was and is to get folks to use first 10w-30, then 5w-30 and now 5w-20 grades to maximize fuel efficiency. A worthy goal, but hardly the criterion I'd use in selecting a long drain synthetic oil ....
About Amsoils oils being BS. I have to disagree. They sell very good oils and definately have their niche market in the oil industry. Why would they want to license their oil when it has been doing a great job through countless UOA and user results. Isn't that what matters in the end?? not some big fancy company slapping on a sticker on a bottle that meets some low ball MINIMUM specs. And the licensing would not make sense to a company like Amsoil, licensing requires a 2-3 year leway, so they couldn't change their formulation until 2 years was up in the license.
don't consider this as a personal bashing as it's not. Amsoil does have the xl7500 series oil at IS API cetified and you may use that if you are leary of warrenty concerns. Then once the warrenty is up upgrade to the top of the line products.
On the flipside, I do **HATE** how amsoil claims ridiculous drain intervals of upto 35,000 miles. I would NEVER go this long without a bypass system installed. They do over-hype their products sometimes, and companies like Schaeffers, Shell and even Mobil offer cost effective alternatives to amsoil and sometimes come close to or even meet the performance. (Delvac 1 is excellent)
About Amsoils oils being BS. I have to disagree. ( [/B]
That does not say the oil is BS.
"Amsoil sells oil as a secondary product their primary product is BS."
haha
Marketing is the BS
Valvoline - "#1 choice of mechanics" - that really makes me run out and buy it huh
Mobil 1 - "First to Market Synthetic Oil" - Mobil 1 was introduced in 1974
Back labels of Mobil 1 products for many years had following statement:
" * exclusive of carrier oil" in substantially smaller print.
While at the same time the front label declared the Mobil 1 as:
"100% Synthetic * ".
The marketing is the BS and it differs from the normal oil companies claims. No matter what you think of amsoils products their propaganda it’s far more ridiculous than any other brand.
Valvoline synthetics for example aren't even synthetics, they are a Group III oil and shouldn't even be compared to Mobil 1/Amsoil class of lubricants.
I agree that if you aren't going to run extended drain intervals, the Mobil 1/Amsoil is a waste of money and 3k dino changes will work for a 150,000-200k mile engine life. For those who use it in combination with a bypass filter, and synthetics bumper to bumper will experience a slight fuel economy increase and greater reliability.
Redvet, isn't that all just copied off the amsoil site? Must have took some work. It is kind of humorous at times to read through it. Example:
Just poking a hole in it.
I have done the math several times and even running extended drain intervals, it isn't cheaper.
And there is still the simple fact of the matter:
The UOA numbers I have seen from my truck using Chevron 10W30 and the UOA numbers posted by others using Motorcraft 5W20, etc. You can't argue with the numbers.
Just what benefit would I (and countless others) derive from running Amsoil? I have been asking that for almost 4 years now. Nobody has ever really given a solid answer.
The API stuff is all fine and dandy. You can argue either way. I STILL say some guys get caught up in this sort of "mind trap" that they are somehow hurting their engine if they aren't using Amsoil. I will agree: synthetics DO have their place. I just don't think it's necessary for most people running 3-5K drain intervals.
My personal belief: Pick a good oil and a good filter. Change 'em both on a regular, reasonable basis, and you are going to get how ever much life the engine has to give. Period.
It just seems so apparent, at least to me, that many (most?) of today's group 3 oils are capable of carrying an engine to the limit of its manufacturing determined life. It also seems apparent that
some folks just can't, or don't want to, believe it.
How many of us know of a modern engine that has failed "prematurely" because of oil? EXCLUDING engine design issues.
That is to say; "Sorry your rod bearings are shot at 89,000 miles and darn, look at the condition of the crank bearings. You should have used Amsoil and you would have gotten 200,000 miles out of this motor".
I never hear of it......
Amsoil is, no doubt good oil. Is it worth the cost? I think not. The numbers seem to verify that for most guys.
So, I'm left to summarize many Amsoil proponents in this way;
"I've got my mind made up. Please don't confuse me with the facts."
edit to add: my sincere apologies. My post had nothing to do with the subject of the thread.
