check engine light
Old Mar 1, 2004 | 02:25 PM
97EXP's Avatar
97EXP
check engine light
My check engine light keeps coming on. But it only comes on when I fill up my gas tank. As long a there is less than 3/4 tank its ok. I have had the 02 sensor change about a year ago. It was about $300.00 at the dealer to get it changed. If I can help it I'll stay away from the dealer in the future. Any advise what it could be the problem.
Old Mar 1, 2004 | 02:30 PM
acerockola77's Avatar
acerockola77
The check engine light can mean a lot of things, you can goto Autozone and they'll pull the codes for free.
Old Mar 2, 2004 | 04:46 AM
marragtop's Avatar
marragtop
Try adjusting the gas cap. Maybe loosen it up to see if the light goes out. As the previous post said, you should get the codes pulled.
Old Mar 2, 2004 | 06:54 AM
Opera House Works's Avatar
Opera House Works
Please put your vehicle year and engine in your profile. This will help in providing you with an answer. While it is likely a 97, you can have three different engines.
Old Mar 3, 2004 | 10:18 AM
97EXP's Avatar
97EXP
I have a 97 Explorer, 4.0L EFI V6 SOHC. About 2 years ago I had the fuel tank pressure sensor and the DPFE (?) sensor and hoses replaced trying to find out what the problem was. Now the light is back on again.
Old Mar 6, 2004 | 04:42 PM
97EXP's Avatar
97EXP
More Info
Just came back from AutoZone where they checked my truck with the code tester. The code P0446 came up. EVAP system fuel tank pressure (FTP) sensor fault. Sounds like the same problem I had before. Any ideas why it keeps coming up. Is there any way to correct the problem without taking it back to the dealer($).
Old Mar 7, 2004 | 04:58 PM
Opera House Works
I would find the tank electrical connector and unplug it, then reconnect it. Just in case there is a bad electrical contact. Bad sensor is uncommon and located in the tank. Sensor is 3 wire and you could probably check it. Dropping the tank is not fun or cheap. Evap leaks are more common and usually involve the solenoid above the spare tire that gets water damage.
Old Mar 8, 2004 | 06:36 AM
98txexplorer's Avatar
98txexplorer
Just a Question......Have you replaced your gas cap. If you have a bad seal on the cap, it wont hold pressure causing your check engine light to come on with that same code.
Just my $0.02
Old Mar 9, 2004 | 09:27 AM
97EXP's Avatar
97EXP
Yes I did replace the cap. I think I may get another cap just to see if that is tha problem. A few dollars on a new cap will not hurt. Thanks for your 2 cents.
Old Mar 9, 2004 | 09:30 AM
marragtop's Avatar
marragtop
Have you tried disconnecting the battery for 5 minutes to clear the code? If so, does the light still come back on?
Old Mar 18, 2004 | 02:11 PM
97EXP's Avatar
97EXP
I have disconnected the battery before when the light came on. But after a few miles it would just come back on. This time I have not done it yet.
Old Mar 22, 2004 | 12:58 PM
97EXP's Avatar
97EXP
Where is and what does the solenoid above the spare tire that may have some water damage look like. I think thats the answer to why my light is on.
