Sponsored by: Auxito
5.4 with "Random Mis-Fire"
Old Mar 6, 2004 | 01:20 PM
Wbruiser2's Avatar
Wbruiser2
Similar problem here, my 2000 F-150 HD edition, 5.4L has developed a sporatic miss. My check engine light came on at first, said misfire on 1 and 4 cylinder. I changed all the plugs and in doing so found that 3 of the 4 on the passenger side were wet and rusty. Ran good at first then started missing a little again. Cleaned the K&N filter, replaced the fuel filter, still does it. Checked the resistance in the COP's, read 7 OHMs consistently. CEL hasn't come on again. So hopefully someone has an idea out there. I'm stumped.
Old Mar 6, 2004 | 08:28 PM
Racerguy's Avatar
Racerguy
Mike what you may have to do is take the truck to your dealer and have them run a power balance test on it. This can be done on the road too with their WDS scan tool/scope. It usually shows which cylinder is missing quite easily.
How did the COP boots look? If there was water and junk in the plug holes I wonder if you have a COP with a corroded end. The boot comes off and then you can see the spring that fits onto the end of the spark plug. Sometimes these get corroded.
Old Mar 15, 2004 | 01:15 PM
H_E_R_N's Avatar
H_E_R_N
UPDATE on original problem...
Had the balance test run and paged thru the history. I have been proven wrong in that a BAD COP does not always throw a code. Number 1 and number 3 were random mis-fire culprits. Changed them and all is well. RACERGUY was correct again about the power balance testing, seems to be the only way to go when a definite code is not being thrown up.
Thanks,
Old Mar 15, 2004 | 02:20 PM
Racerguy's Avatar
Racerguy
Thanks for letting us know what you found.
Why is it that when I read where you wrote BAD COP I instantly though there should be NO DONUT behind that?
brettdawnj
1997 - 2003 F150
69
Dec 1, 2017 08:46 AM
capesteve
21
Feb 10, 2017 07:08 AM
kmanley
2004 - 2008 F150
Jan 9, 2013 10:39 PM
last_leaf
1997 - 2003 F150
Feb 11, 2006 04:05 PM
H_E_R_N
Mar 2, 2004 10:33 AM
