1990 f-150 ignition
Old Mar 1, 2004 | 09:05 AM
CanadianBrian's Avatar
CanadianBrian
1990 f-150 ignition
My truck won't start because turning the key in the ignition doesn't push the rod properly that connects to the starter switch at the base of the steering column. The rod does move back and forth but has alot of play in it. How is it connected to the ignition switch? Is this an easy fix or am I in for a large repair bill?
Thanks in advance.
Old Mar 1, 2004 | 02:50 PM
Jarrett T's Avatar
Jarrett T
Just went through this. Did you remove the steering wheel and and shroud to examine the parts yet? If not, do that 1st and I'll take you from there. The actuator rod is connected to the problem part - the upper actuator. Drop by a Ford Parts and ask for the diagram showing you these parts so you'll know if it's broke or not. I did all kind of stuff to mine thinking it wasn't broke until I seen a picture of it. The upper actuator has a tendacy to break off on down in the column and you'll not be able to see it initially. Do this and check back.
Terry
Old Sep 28, 2006 | 08:28 PM
dasbutcher's Avatar
dasbutcher
Just had this happen today, at least I'm pretty sure it's one of the acuators, are there diagrams available online?
Old Sep 28, 2006 | 09:32 PM
jroehl's Avatar
jroehl
The good news is that you can take the shroud off your steering column, pull out the busted part, turn the ignition on (not to start), then use a screwdriver to push in on the remaining piece and start the truck. I did this for a few days until I had a chance to get the part.
Jason
P.S. You don't need diagrams. Just take the shroud off, you'll figure it out. The broken actuator is a quarter-circle from the ignition to the 12 o'clock on the column, then goes straight forward along the column. It's a cheap, pot-metal part that breaks easily.
GodsHammer
Jan 23, 2017 10:00 AM
Paredez
1997 - 2003 F150
Jun 9, 2012 09:03 PM
Bandit91
Mar 12, 2012 11:36 AM
73 ford guy
Oct 15, 2011 03:13 PM
GA boy
Modular V8 (4.6L, 5.4L)
Feb 5, 2011 10:11 AM
