Predator Specific Question
I agree with getting the guages first it is cheap insurance against frying your tubo or even worse. If you can't afford the $200 for the guages then don't buy the exhaust. It is better to know what the true temps is than it is to think they are ok just because you opened up the exhaust.
King Ranch why did you opt for the cat back instead of the whole system I am looking at both and I need some feedback.
I didn't want to deal with warrenty issues and also I heard that the turbo likes a little back preasure.
I talked to the folks at Motorhaven about running a Predator on my truck..They said NO PROBLEMShould I do any towing, than the gauges would be installed (not til summer) and MAYBE on another truck!!!
Any hard facts out there.....
Here is some EGT Data.
This is the truck and conditions:
2003 Ford PSD Super Cab Short Bed
Weight 6500 Pounds with Driver
0603 Build Date
Original Flash
5500 Miles
No Problems
265- 75 -R -16 30.5 inches tall
3.73 Posi
Predator set at 65 HP
K&N Cold air with mass air
No other modifications
Auto Meter EGT gage with probe installed with clamp >2" from turbo outlet flange.
Air Temperature 40 Deg.
20 MPH head wind
Idle Warm 400 Deg.
Around town, max 50 MPH 400- 600 Deg
75 MPH Cruise level no boost 590 Deg
85 MPH Cruise level no boost 600 Deg
Add 10 lb boost for hill +10 Deg
Passing floor it >10 sec 80 – 100 MPH 25 LBS boost 650 Deg
Full throttle til speedo goes back to zero at 3000 RPM 790 Deg
Full throttle until 3300 RPM (maybe ¼ mile from 80) 800 Deg
Engine still accelerating strong at 25 lbs boost at 3300 temperature seems to be maxed out at 800 Deg.
There is a lot of info on the main Predator thread including this test I did a couple of weeks ago:
0603 Build Date
Original Flash
5500 Miles
No Problems
3.73 Posi
20 MPH head wind
Idle Warm 400 Deg.
You leave nothing to chance.
GREAT stuff
But I agree with you, don't do anything that they can use against you or gives the impression even of a mod that CAUSED the problem...
And then there's always OTHER dealers if this one is giving you problems...
Ask for an oasis report to ensure they put ALL your complaints in... (you DID keep records didn't you?)
then have a second set of "service" eyes to look at it...
Warranty work does NOT have to be done at the purchase place - but you can get some perks if they take care of you...
good luck with it !
The problem is that I want my truck fixed "for sure".. And we take all of our Fleet Warranty and any "spill over" work there..It's kinda hard to be assertive, or borderline "mean" to the guys that you see on a regular basis!!
I'm documenting it very well, especially after reading the posts here about the Buy Back "arm wrestling" that is required to get Ford to "pony up" to suppying a good truck, that they got good money for..
It's in the shop right now for the R/main leak, and they gave me a Chev. Cavalier to drive!! Lotta fun there boy!! They'll get one more chance at a fix, and if they don't get it right, I'll take it to another dealer, and get the area Master Tech involved if he isn't already..
SURE MISS that SD!!! .. Once driven...Hard to go back!!!
You don't have to be mean...
on my 02 buyback I was just "concerned" when I talked to them...
and stayed that way for weeks :-)
and used a lot of this....
"Would you want your wife (little daughter, young son) whatever to ride in this thing in it's condition?"
OR
"What would you want done if this were your truck?"
or
"How would you fix this situation?"
or
"what do YOU think is fair?"
I gave them the chance to resolve it....
course if they didn't come up with the "right" answer
(what I wanted to hear)
I'd ask the quesion again with a little more "concern" in my voice...
Worked for me !!!
So CB..
Where exactly did you tap into???
I was thinking about going into the Service Area wearing a neck collar, and telling them that I slipped on an oil spot in my driveway!!! and,, Oh,, by the way "who is your insurance carrier??
Ford just called...Truck is ready..with no leaks...We'll see.....
Hope it's true..Want to order up the Predator!!!!
