Engine shaking while driving
Old Feb 29, 2004 | 08:09 PM
1982fordf100's Avatar
1982fordf100
Today when I started my 1995 F150 to leave work I noticed a shaking from the engine. I pulled out of the lot and drove for about 5 minutes which was about 2 miles. It was shaking so bad that it seemed like not all of the cylinders where firing. My shifter (manual trans) was shaking all over the place. The more I pressed the gas the worst it got. So the first chance I got to pull over I did. I stopped at a gas station and called my dad, he said he would meet me half way. So while I was on the phone I just let my truck continue to idle. It seemed to idle ok. I let it idle for about 5 or 10 minutes and then when I got in to drive away all was normal. It was sure wierd. I replaced some vacuum hoses which where cracked. I don't know if that was the problem or not. I sure hope it was. Any clues? Thanks Fred
Old Mar 7, 2004 | 04:05 AM
Karlen's Avatar
Karlen
Did you problem go away after you replaced those hoses? Im getting an occational shake when im driving then it goes away, but i never actually had to pull over, i just speed out of it.
Old Mar 7, 2004 | 09:28 AM
oldhalftons's Avatar
oldhalftons
you say 95 model year, I've never worked on a EFI 300, but when a non-EFI 300 starts shaking and not running , its often the EGR mounting gasket has blown out, the EGR is loose or just stuck open. cracked or missing vacuum cap can make it runn real bad at idle.
shall208
1997 - 2003 F150
Jan 18, 2011 11:40 PM
xshovelheadx
Oct 30, 2009 04:38 PM
Danny0295
2004 - 2008 F150
Jun 6, 2009 08:39 PM
1982fordf100
Mar 2, 2004 08:48 PM
chadcole26
1997 - 2003 F150
Feb 26, 2004 07:13 PM
