No Power?
Old Feb 29, 2004 | 06:09 PM
Pi150's Avatar
Pi150
Question No Power?
I have an 87 F150 4x4 with the 4.9 L Engine. My problem is there is no power to the ignition switch. I have change the switch and checked the plug with a light tester and no power. Any suggestions?
Old Mar 2, 2004 | 08:21 PM
parks911's Avatar
parks911
Are your battery terminals tight & corrosion free?
Is your battery charged?
Is your solenoid good?
Do you have any loose wires from the battery to the solenoid? solenoid to the starter? starter on back? Around the distributor?
Check your fuse panel, there should be a fuse for the ignition, if it is blown you won't get nothing.
