Injector Pressure
Old Feb 29, 2004 | 01:38 PM
Fully_Loaded's Avatar
Fully_Loaded
Question Injector Pressure
On my 91 (see sig). What pressure are my injectors?
Old Feb 29, 2004 | 03:56 PM
StrangeRanger's Avatar
StrangeRanger
They should show 35-40 PSI at the Schrader valve KOEO.
Old Feb 29, 2004 | 07:04 PM
Fully_Loaded
What do they fire at though. I see a lot of injectors for sale that are 19lbs. Is this right?
Old Feb 29, 2004 | 10:09 PM
EPNCSU2006's Avatar
EPNCSU2006
That's flow rate - 19 lbs of fuel per hour max flow. Stock 302 has 19 lb/hr injectors.
Old Mar 1, 2004 | 05:48 PM
Fully_Loaded
What can I upgrade to without any major changes? Will it make a difference to go with a little more fuel?
Old Mar 1, 2004 | 06:52 PM
EPNCSU2006's Avatar
EPNCSU2006
Are you going to be feeding the engine extra air to go along with this extra fuel? You'd have to calibrate the computer (with a chip) for the bigger injectors, but there wouldn't be any more fuel getting to the engine then, so what is gained? There are other things that would be more beneficial than larger injectors. The stock injectors can handle a little over 300 hp, so unless you have built up the motor a lot, stock injectors are all the flow you need.
Old Mar 2, 2004 | 07:27 AM
StrangeRanger
Exactly!
Bigger injectors will not add any HP on a stock engine. Unless you have modified things to the point where the stock injectors cannot keep up, they are a waste of time and money -- and will probably give you drivability problems as well.
Depnding on how hard you want to push theduty cylce and your actual BSFC the stock 19# units are good for at least 245 HP and possibly as much as 285 HP. 300 HP requires a 100% duty cycle, not rweally a good idea.
Old Mar 2, 2004 | 06:00 PM
Fully_Loaded
I plan on building the engine soon it has 300k plus on it. I am going to bump up the compression to about 9-1 put a medium cam in it and so forth. I am not going to drag race it but according to desk top dyno I will be gettin about 290 ponies and about 400 lb-ft of torque
Old Mar 2, 2004 | 10:08 PM
EPNCSU2006's Avatar
EPNCSU2006
I don't believe those numbers with just 9:1 compression and a medium cam.
Old Mar 3, 2004 | 11:58 AM
StrangeRanger
400 ft-lbs is a lot with any streetable cam, I'd guess it's virtually impossible with stock heads. 290 HP is reachable, depending on what is included in your "and so forth" but frankly, I'd bet against.
Old Mar 7, 2004 | 07:07 PM
Fully_Loaded
Here is the exact numbers and specs. If you have desktop dyno plug this in. The numbers are: (at the flywheel)
Engine RPM Power Torque
2000 135 354
2500 174 365
3000 212 370
3500 247 370
4000 283 371
4500 310 362
5000 329 346
5500 341 325
Not quite 400FtLb but very close
Block: 302
Bore:4.032
Stroke:3.000
Heads:Low performance/Ported, Large valves
Intake Valve:1.94in
Exhaust Valve:1.65in
Compression:1
induction Flow:700CFM (Not sure on exact CFM)
Manifold Type: Tuned Port (not 100% sure of TPI or Sequential)
Exhaust: Large tube headers open exhaust.
Cam Shaft: Comp Cam XE250H
Lifter: HYD.
Specs @ seat to seat
Int. Lift: .460in
Exh Lift: .474
Old Mar 8, 2004 | 01:52 AM
Ford_Six's Avatar
Ford_Six
Actually, throttle body airflow is closer to 600cfm, and assuming you will be running mufflers on this thing, your numbers drop to 356hp and 345lbs/tq. Even at this, you will need to have to reprogram.
Old Mar 8, 2004 | 06:46 PM
Fully_Loaded
Open exhaust 3" all the way back with headers
Old Mar 9, 2004 | 11:04 AM
StrangeRanger
Desktop Dyno is notoriously optimistic in the numbers it spits out. Don't be surprised to see lesser results when you put it on the Dynojet
