Sponsored by: Real Truck
Shocks
Old Oct 18, 2001 | 11:09 PM
DiamondF350's Avatar
DiamondF350
Shocks
I have a 2000 F350 CC LB Dually with 15000 miles and was wondering what the general word around here on shocks is. Thanks in advance.
Old Oct 19, 2001 | 04:17 PM
powerstroker250's Avatar
powerstroker250
Shocks
JUNK!!!!!!!!!!!!!!
Try some aftermarket shocks and you will be amazed. All my Ford shocks were leaking at 25k.
Les
Old Oct 19, 2001 | 08:31 PM
DiamondF350
Shocks
Thanks for the Advice.can any tell me what kind works the best for all around street driving It is a 4x2 and I would like the best without makeing the ride any worse. Thanks again
Old Oct 20, 2001 | 02:08 PM
powerstroker250
Shocks
Most poeple seem to be using Edelbrock, Bilstein or Rancho 9000's which are adjustable.
Les
Old Oct 23, 2001 | 04:08 PM
gotv10's Avatar
gotv10
Shocks
I replace the OEM shocks on my F250 SD with Edelbrock IAS shocks. They really improved the ride.
Old Oct 24, 2001 | 08:55 AM
odinmurphy's Avatar
odinmurphy
Shocks
Did anyone change their own shocks? Are changing shocks ona superduty any differt than changing them on anything else? Anything new to be concerned about or bobby traps waiting to bite the unsuspecting shadetree mechanic?
Thanks
Murph
Old Oct 29, 2001 | 03:24 PM
harald's Avatar
harald
Shocks
I put the Rancho RS9000 shocks on my dually to help with camper hauling. The stock shocks allowed too much sway with that top heavy camper loaded. With the Rancho shocks, I can crank up the dampening when the camper is loaded yet keep a smooth ride when unloaded. BTW, they work so good for dampening sway that I will not carry a camper without installing those shocks.
As far as install goes; it's a piece of cake. Just remember that the front shock mount nuts have little brackets on them, so you need to turn the bolt. Of course if you get some Nitrogen filled shocks (doesn't apply to the above mentioned Rancho shocks), then you have to be careful when cutting the retaining strap because they will extend in a brisk manner and could hurt you.
2000 F350 CC DRW Lariat 4x4 LWB 4R100 V10 4.30ls with Torklift tie-downs/Superhitch and Rancho RS9000 and Ride-Rite air springs.
1998 Alpenlite Pendelton 11'10" Slide-in camper with all options.
Old Oct 29, 2001 | 08:44 PM
DiamondF350
Shocks
Thanks for your post Harald it eas very helpful and I belive I will go with the 9000's I think I will also go with the incar adjustable kit so I can tune and drive.
Old Oct 30, 2001 | 09:18 PM
brentca2000's Avatar
brentca2000
Shocks
