Computer help needed
Old Feb 29, 2004 | 10:29 AM
J. E. Ray's Avatar
J. E. Ray
Angry Computer help needed
Some how I have managed to erase my D: drive. My PC states this drive is no longer available. I go to DOS and the same thing. How I erased it I dont know. How can I reinstall it.
Thanks in advance.
Old Feb 29, 2004 | 10:31 AM
FireHazard's Avatar
FireHazard
Sounds like you deleted the partition, what OS are you using?
Old Feb 29, 2004 | 10:35 AM
Lcashmer's Avatar
Lcashmer
Could also be that the drive just went bad if you have two physical drives.
Old Feb 29, 2004 | 10:37 AM
J. E. Ray's Avatar
J. E. Ray
windows 98
I am almost sure I am at fault. I think I disabled it some how.
Old Feb 29, 2004 | 10:41 AM
jor's Avatar
jor
What is your D: drive? Is it an actual hard drive, a logical drive, a CD?
jor
Old Feb 29, 2004 | 10:43 AM
J. E. Ray's Avatar
J. E. Ray
cd
Old Feb 29, 2004 | 11:19 AM
ChiefsFan's Avatar
ChiefsFan
Sounds to me like you just need to reinstall it since it is a CD drive.
Old Feb 29, 2004 | 06:59 PM
J. E. Ray's Avatar
J. E. Ray
How do I do that.
Old Feb 29, 2004 | 07:24 PM
mikebon08's Avatar
mikebon08
If it's a cd-rom drive, you can't erase it. If it doesn't show up, it's because either the drive has died or a cable has come loose. How old is the computer?
Old Feb 29, 2004 | 07:30 PM
peppy's Avatar
peppy
You can erase the driver software. ?
If thats the case, you may still have the floppy to reload, or can download from the internet.
Old Feb 29, 2004 | 07:45 PM
shakemyspeare's Avatar
shakemyspeare
Go to Start = Control Panel = Add/Remove Hardware. From there, there should be an option to add or re-install the CDROM drive. There may be a generic driver built into 98 that will let you re-install the CD-ROM, if not, then you'll have to go search for the driver files that you need. Look for a brandname or model number on the CD-ROM and then just plug that into google or your favorite search engine. You shouldn't have any problems finding drivers.
mikebon08's Avatar
mikebon08
Win98 has its own cd-rom driver, does not need a floppy to reload a driver.
Old Feb 29, 2004 | 07:59 PM
peppy's Avatar
peppy
Been so long since I've used win98. I cant remember if it even worked. I've got a win95 system, I know it doesnt work, the 2000 version, I think it works. LOL WinXP, not sure it ever worked.
Old Feb 29, 2004 | 08:09 PM
Mil1ion's Avatar
Mil1ion
The instructions to get it going are on MSN.
What code is it ?
I might have the instructions right here in front of me..
Check this out
http://support.microsoft.com/default...;en-us;Q133240
Old Mar 1, 2004 | 09:57 AM
david.brady's Avatar
david.brady
I would have to go with the comment that maybe the wire got disconnected or that it is disabled. Most of all CD drives are plug and play, no drivers just insert and go. Your device manager will be able to give some insight if the system even acknowledges its existence. Check ad see if it shows up and then go from there.
