Gas Cap Not Tight Causing Code
Old Feb 29, 2004 | 09:37 AM
kobrak12's Avatar
kobrak12
FWIW, that's what the shop told me was the problem when I took it in cause the check engine light was on? Said to make sur ethat the truck is not running while fueling, cap is on tight after fueling, and to not run it low on gas. Sound right?
Old Feb 29, 2004 | 11:43 AM
PaulC's Avatar
PaulC
Yep. Thank OBD-II for all this.
Old Feb 29, 2004 | 10:19 PM
tsdrallyer's Avatar
tsdrallyer
I had to replace the rubber O-ring on my gas cap about 95K miles, to get a good seal. Solved that problem for .$85.
