4-speed?
Old Feb 28, 2004 | 08:12 PM
X-1's Avatar
X-1
4-speed?
What 4 speed tranny will work in a 1970 f-100 with a 302, and 3 speed. I would like to swap out the 3 speed fo a 4 speed, is there any direct swaps?
Old Feb 29, 2004 | 03:59 PM
bob arrington's Avatar
bob arrington
np435 and i think you will need a 302 bellhousing /flywheel, unless you can find a 302 4speed ,bob
Old Feb 29, 2004 | 04:29 PM
X-1's Avatar
X-1
is the 3 speed bellhousing and fly wheel different? I already have the 302/ 3-speed combo
Old Feb 29, 2004 | 07:33 PM
Boss_358's Avatar
Boss_358
There is a chance that the bellhousing may be the same. I am not absolutely sure though.
Old Feb 29, 2004 | 09:22 PM
78fordman's Avatar
78fordman
the 302 bellhousings i would think are all the same, one off of a 300 or 351W will work also. Flywheels should be the same i think. I am pretty sure the flywheels are engine specifiec, and either auto or man tranny.
Old Feb 29, 2004 | 10:32 PM
X-1's Avatar
X-1
That's good news. Is the 435 only come with the granny, or can you get a normal 4 speed version, like the muncie, which is another question, did muncie only make tranny's for the bowtie?
Old Feb 29, 2004 | 11:44 PM
doc_nomad's Avatar
doc_nomad
Cant you put a toploader in there, just like the mustang? Thats a bulletproof regular 4 speed w/o granny gear.
Old Feb 29, 2004 | 11:49 PM
X-1's Avatar
X-1
Now that would be sweet, but I think the toploaders use a different cltch set up, and yoke. I am looking for an easy swap, It would be nice if an early mustang tranny would work, I will have to do some more research as to whats available, I wonder if advanced adapters has anything for putting the m-21 rock crusher in there, that's a killer tranny.
Old Mar 1, 2004 | 09:42 PM
swann79's Avatar
swann79
The Ford 3-speed, NP235, and BW T-18 all use the same bellhousing and flywheel. I had all 3 on an old 66 F-100 w/ 390.
The only difference is usually in the clutches... specifically the tooth pattern.
Old Mar 2, 2004 | 12:53 AM
X-1's Avatar
X-1
whats a np 235?
Old Mar 2, 2004 | 12:55 AM
X-1's Avatar
X-1
one last question, so far very good information. What about the driveshaft, do they share the same yoke, or are they different?
Old Mar 2, 2004 | 06:47 AM
Boss_358's Avatar
Boss_358
This is what I was getting at. The transmission pattern on the bellhousing itself is usually the same from make and model variations. I have about 3 different bellhousing laying around, and I think all had a different transmission bolted to them. But each housing is near identical.
X-1, I think he means NP435.
Old Mar 2, 2004 | 06:49 AM
swann79's Avatar
swann79
Originally posted by X-1
whats a np 235?
Sorry, had a brain fart. I meant NP 435.
Old Mar 2, 2004 | 09:21 AM
bigwhtbco's Avatar
bigwhtbco
correct me if i am wrong, but wasnt the m22 deemed the "rock crusher transmission. offered on the 454 chevelles and most gm high output 454(not 396) applications
Old Mar 2, 2004 | 12:35 PM
X-1's Avatar
X-1
yes, my mistake, but also available for the smallblocks. Got to thinking about input shafts, and with a different clutch it wouldn't matter, dumb question on my part. What about lentgh of trannys, and out put shafts, will the same driveshaft work with a np435 as with a 3 speed? Hey, while I am asking what about tranny mount, same mount?
