i have a 94 5.8 lit bronco and over the last year i have been having some problems with the transmission. i bought it from a guy a couple years back and he pulled a bout with it and now if i go 80+ on the highway and slow back down it begins to shift really hard. the fluid level is correct everytime i check it, and it usually goes away in a few days or in about a week or so. do i need to have it rebuilt? thanks for the help
Originally posted by tinman57 Have the codes pulled from the EEC and see what it is showing.You can pull them yourself or have it done.Some auto-parts stores will do it for free.
what might be happening is the computer senses slipping in the torque converter, therefore the transmission goes into a "limp" mode, it will shift hard for a while, then it might go back to normal, and once it senses slippage again, it will reluctantly return to the limp mode, chances are you will need a rebuild soon, sorry for the dissappointing news.
beefing up a transmission may include, larger valve body ports, larger transmission pump, more/stronger clutches, shift kit, and many updates that were faulty from the factory. This may cost a little bit more but most people are satisfied with their NEW transmission. If you choose to have it rebuilt ask them what a regular transmission overhaul includes.
