Warm idle problem
Old Mar 4, 2004 | 08:02 PM
jswalker145's Avatar
jswalker145
Yep, that's it. The vacuum line from it to the throttle body was pretty shredded, so I replaced it. Made the truck run better, but didn't solve the problem. Just went out in the snow and cleared the codes and rechecked them (11/11) and it still does the same thing.
I'll try to get downtown over the weekend and get a manual to see what the ECT (and other sensors) should measure and check them all. I'll keep you posted.
Old Mar 8, 2004 | 10:48 PM
jswalker145
Resolved: Warm idle problem
The problem turned out to be a bad throttle position sensor, and all is back to normal now (almost.) Unfortunately, in the process of replacing the TPS, I split the coolant line that runs to the throttle body, so now it makes a handy lawn sprinkler.
Thanks EPNCSU2006 for all your help.
dstrahm
Aerostar
17
May 13, 2025 06:04 AM
pinkpantherusmincus
Aug 26, 2015 12:47 AM
Econley
26
Jul 4, 2015 11:44 AM
Superduty.pride
Dec 3, 2013 10:34 AM
Jlckb5
Nov 7, 2011 07:50 AM
