Why does it smoke?
Old Feb 28, 2004 | 05:35 PM
jj292's Avatar
jj292
Why does it smoke?
I just got the engine in my 1977 F150 to run it is a 460 with a C6. The problem I am having is that it starts and runs great, but it spits out a ton of thick black smoke. I put in fresh gas, cleaned the fuel pump, rebuilt the carb, and checked all the plugs but it still smokes. Its not buring oil and it is running on all cylenders so what is going on?
oh yah it was sitting for about 5 years if that makes a difference.
Thanx, JJ
Old Feb 28, 2004 | 06:11 PM
hreed's Avatar
hreed
Black smoke often means it is running rich. What kind of mileage are you getting? Put a vacuum guage on it to see if there is a leak. What did the plugs look like? Were they clean?
Old Feb 28, 2004 | 09:01 PM
jj292's Avatar
jj292
the plugs were clean with the slight brown that is normal. That would make sense that it is running rich since ir just rebuilt the carb. So how do I lean it out? I do have a vacume gauge but it do not know how to use it can someone give me the 101?
Thanx, JJ
Old Feb 28, 2004 | 10:23 PM
rainbowATF's Avatar
rainbowATF
vacuum gauge
Hook up vacuum gauge to manifold vacuum and compare to readings in the following website.
http://www.users.bigpond.com/ergoff/vac1.htm
Old Mar 1, 2004 | 01:34 PM
FERacing66's Avatar
FERacing66
id say its the carb. id play with the air/fuel mixture screw while its running and see if you can lean it up and stop the smoke.
Old Mar 1, 2004 | 02:53 PM
ranchero77's Avatar
ranchero77
probably carb but if it idles good, adjusting the idle mix screws won't cure a "ton of thick black smoke". if it does have a poor idle after you checked and fixed any leaks you can use the vacuum gauge to fine tune the mixture screws for max vac using only 1/8 turn increments or less.
When does it smoke? up hill? WOT? going around turns?
Old Mar 4, 2004 | 04:07 PM
71swissaqua's Avatar
71swissaqua
Make sure the choke is opening up
CLint
