Sponsored by: Real Truck
Rear end gears!
Old Nov 8, 2001 | 08:57 PM
DiamondF350's Avatar
DiamondF350
Rear end gears!
I hope I don't get into trouble for posting this here but my brother and I just bought new trucks. Mine a f350 CC LB DRW and his a F250 CC SB SRW Both V10's any way at 80 mph his tach reads 2300 mine at 80 reads close to 2900 I have the 4:30 limited slip he has the 3:73's anyway my truck is new and if anyone wants to trade their 3:73's that are new for my 4:30's let me know my ad is posted in the classifieds Thanks
Old Nov 8, 2001 | 10:02 PM
Spook's Avatar
Spook
Rear end gears!
Keep the 4:30's and get a bigger tire like maybe 305's, this tire size increase will move you closer to the 3:83's. A lot of people have done this already and that is what I intend to do when my new truck arrives any day now. Good luck.
Old Nov 8, 2001 | 10:05 PM
Spook's Avatar
Spook
Rear end gears!
oops, I assumed you had 4 wheel drive like what mine will be, If it's 2 wheel drive i'm not sure what tire size will fit that.
Another weird observation is the fact that I replied to my own post.....weirdness.
Old Nov 9, 2001 | 05:50 PM
V10man's Avatar
V10man
Rear end gears!
Also keep in mind that your brother has 265 tires and your dually prolly has 215 or 225's which are smaller. You could go to a 235x75x85 which are about the same diameter as the 265's.
Old Nov 10, 2001 | 04:00 PM
DiamondF350
Rear end gears!
So your saying a taller tire will help?
Old Nov 10, 2001 | 08:12 PM
V10man's Avatar
V10man
Rear end gears!
Yep, a taller tire will change the overall ratio. Have your dealer reprogram the speedo after the tire change. One drawback to taller tires it lowers the towing capacity of the truck.
Old Nov 11, 2001 | 07:16 PM
DiamondF350
Rear end gears!
So It will be a noticeable difference with a taller tire like half way between the two more or less? thanks for the input I do appericate it.
Old Nov 11, 2001 | 08:34 PM
FordMan57's Avatar
FordMan57
Post Rear end gears!
I think I remember seeing on Horsepower TV or a similar show that every 1" in tire size change, is about .1 in overall gear ratio change.
Ex: If you went from a 33" tire to a 35" tire with 4.30 gears...it would lower your overall ratio to 4.10....or something like that?????????????????
Old Nov 11, 2001 | 11:24 PM
BigDeezil58's Avatar
BigDeezil58
Rear end gears!
Pepinbilt
Apr 9, 2015 12:41 PM
1medic
6.2L V8
Nov 27, 2014 12:44 PM
sbechtold
Jan 25, 2008 12:53 PM
Jimmy Pet
Modular V10 (6.8l)
19
Feb 20, 2004 06:27 PM
jrd1967a
Jul 20, 2002 09:56 PM
