spark plugs
Old Feb 27, 2004 | 10:16 PM
super sized's Avatar
super sized
spark plugs
Getting near 90,000 mark so I asked my local dealer when should I change plugs he said at 100,000 but I did a sneak peak at the plugs gap was up to 58 high speed glazing on the top.Can't wait any longer what are the best spark plugs on the market for this mammoth creature?
Old Feb 28, 2004 | 04:01 PM
Landyot's Avatar
Landyot
Platinum tipped plugs.
Old Feb 28, 2004 | 04:49 PM
Monsta's Avatar
Monsta
Sit. Stay.
Stock ones are just fine. Look how long they lasted you!
Old Mar 1, 2004 | 08:29 PM
firstford's Avatar
firstford
So what's the best way to change the plugs? I've never owned a vehicle so technically-advanced; or one with so many spark plugs! I changed the plugs in the Mini today; took 5 minutes. I don't even recognize half the "stuff" in the X's engine compartment.
Old Mar 1, 2004 | 09:12 PM
super sized
Doing mine for the first time checked one took me 21 mins total time anybody got any shortcuts or suggestions.
Old Mar 2, 2004 | 12:14 AM
Monsta's Avatar
Monsta
Sit. Stay.
Keep your afternoon clear.
Which one was that that took 21 minutes?
Old Mar 2, 2004 | 08:50 AM
rlh68050's Avatar
rlh68050
The Motorcraft platinums are the best plugs for your truck. Do not get Bosch platinums, they will not preform well in this application. Bank 2 (drivers side) is not to bad to do, bank 1 (passenger side) rear most plugs are really tough to access. I believe you need to remove the fuel rail on that side.
Old Mar 2, 2004 | 11:19 PM
super sized
Too late bosch it is no trouble yet gapped @0.54 instant results went from 11mpg to 13.7mpg. The total time was one hour on the driver side one hour fifty minutes on the passenger side I just unloosened the fuel rail on each side so I could get to the coil off easy price the coil at local parts store $49.00 PER COIL. Didn't get autolite had bad encounter on my mustang.
Old Mar 3, 2004 | 07:42 PM
sdilling's Avatar
sdilling
Do you have to change coils with plugs
If the coils haven't failed is it required to change them when the plugs are replaced? Assume they either work or they don't, would a check egine light come on if a coil failed? With the V10 you may not feel a single failure, although you would see gas milage drop a bit?
Thanks...
Old Mar 4, 2004 | 07:24 PM
super sized
Yes the check engine light will come on becuse it is in the scan code but which say that a cylinder is gone.B ut yes a v10 won't feel it
Old Mar 4, 2004 | 07:28 PM
super sized
Would not change coil unless they looked bad like ( busted boot,real loose spring,etc...)
Old Feb 11, 2023 | 10:23 AM
railroader's Avatar
railroader
If it ain't broke, don't fix it. Engine light may or may not come on, and it can even come on and go away. I drove my truck several thousand miles, only to find that one of the coils was arcing like a lightning bolt. I never saw it. My Ford truck mechanic friend saw it and replaced it, and the problem went away. No codes or anything. Just that intermittent engine light. That one coil cost me $145, from the dealer. Only spend what you need to, since eight coils would sit over a thousand. Plugs? Just change them on the 100,000 mark. It's rare that one goes bad, but it does happen. Mileage will suffer if it is just spitting gas and not burning it, but it may not be as noticeable unless you do as I do, and spend too much time watching the mileage display. During the cooties pandemic, I drove to the interstate and back, early in the morning, for a couple years. Gas was cheap and the idiot drivers were all at home wearing their masks and fearing the Fauci gods, so I got to watch my mileage over the same course. That was when the engine light came on and off, several times. I noticed a small mileage drop.
