valve train problem
Old Feb 27, 2004 | 08:37 PM
tess100's Avatar
tess100
valve train problem
i am building a 71 429 dove c heads crane cam 522 / 530 lift . new lifters stock rockers , stock push rods. new springs etc... problem is i assembled everything and have about 3/16 gap between rocker and valve tip with nuts tightend down. do i use longer push rods ? and why did this happen ? every thing is back the way it came out ?. next rocker arms touch on side of retainers they are crane retainers and they dish down , the stock ones dished up , i was told to grind a off the railes on rockers to provide clearance , what is your opinion ? next were do i put timing gear it has 3 slots -4 , 0, +4 if it is to be 0 what does +4 do ?
Old Feb 28, 2004 | 11:14 AM
buzziscrazy2's Avatar
buzziscrazy2
Damn you have a mess, buying **** from Summit ?
Who set up the heads ?.......did they check your seat pressure?
Did you mill the heads?.......what head gaskets did u use?
Old Feb 28, 2004 | 06:16 PM
classic79's Avatar
classic79
You kinda have a mess going on now, as I'm sure your aware of.
You need to buy/make an adjustable pushrod to determine the correct length pushrod you need. Since your not using a stock cam the stock pushrods and rockers ain't going to work to well.
You might want to goahead and get some roller rockers too.
set at 0 degrees. the + and - indicate how much advance or retard the cam will be set at. You want it set straight up at 0
Old Feb 28, 2004 | 10:50 PM
LxMan1's Avatar
LxMan1
Your Crane Cam has a smaller base circle that the stock cam . Contact Crane for the proper pushrods.
Old Feb 29, 2004 | 10:19 AM
tess100's Avatar
tess100
thanks guys i have looked for answers every engine guy i know and as usual i end up with my answers rite here. this forum is very good place for amature builders thanks again and keep up the good work .im off to crane now to look for diff push rods and rockers
ssn randy
Jul 6, 2025 01:24 PM
htownoag
17
Oct 19, 2015 10:47 AM
masseysbronco
Mar 28, 2014 02:13 AM
73 fourxfour
38
Feb 20, 2011 02:55 PM
65'f1004x4conver
Oct 25, 2006 08:12 PM
