Sandblasting Question??? again
Old Mar 1, 2004 | 10:02 PM
ford390gashog's Avatar
ford390gashog
isn't that the honest truth
Old Mar 2, 2004 | 05:54 AM
sancochojoe's Avatar
sancochojoe
After you sandblast, what do you guys normally do.
Do you give it some type of chemical wash before applying self-etching primer and or Zero Rust on the frame??
Old Mar 2, 2004 | 06:44 AM
marc9000's Avatar
marc9000
I'm not sure about the zero rust product, but I don't think any further prep is necessary for a self etching or epoxy primer, as long as it's done fairly soon after the sandblasting. (same day)
marc
Old Mar 2, 2004 | 07:38 AM
Huntsman's Avatar
Huntsman
I try to wipe my panels with a 'wax and grease' remover before priming, just in case some one touched the panels. Oils from even a 'dry' hand can cause the paint to turn lose.
Old Mar 3, 2004 | 06:02 AM
sancochojoe
Got a different nozzle and Dadman Gun and everything works great now. Paint stripping off like magic so this weekend I will blast the frame.
Hey do any of you guys blast the axles??? or leave that alone?
Old Mar 3, 2004 | 06:07 AM
bob-63-292's Avatar
bob-63-292
I did the backing plates, drums, and front axle.
Bob
Old Mar 3, 2004 | 06:24 AM
sancochojoe
What should I not sandblast?
Old Mar 3, 2004 | 08:03 AM
bob-63-292's Avatar
bob-63-292
Don't sandblast the obvious
That is, be careful around the spindles, don't blast the drum faces (where the shoes meet the drum, I used duct tape on these fwiw), bearing and seal locations, etc.
The abrasives can pit the metal which will have deliterious effects!
Bob
Old Mar 4, 2004 | 06:33 PM
sancochojoe
how much did it take anyone to sandblast.
It took me a 100 pound bag to do a stinking running board.
How long did it take someone to do a frame and how many bags did it take??
Old Mar 4, 2004 | 08:03 PM
marc9000's Avatar
marc9000
If you do a really thorough job on something with a big buildup of old paint etc. it can take a lot of time and sand as you found out. A suggestion would be to go over it first with a grinder or wire wheel, anything to give the sandblaster less work to do.(sandblasting will take out many of the grinder marks you might leave)
marc
Old Mar 4, 2004 | 09:06 PM
sancochojoe
I was thinking of spraying a layer of stripper to loosen the paint.
God, the previous owner layered a whole bunch of bondo in this dent instead of pulling or hammering the dent out. The guy must of had an inch of bondo in this dent.
Sandblasting can really tell on you.
Old Mar 4, 2004 | 10:15 PM
marc9000's Avatar
marc9000
Stripper works great on bondo - saves making a lot of dust by not having to grind it out. Load the stripper on, cover it up right away (with garbage bags or something) to keep the chemicals in the stripper from evaporating, and give it a few hours to work. A rigid putty knife or gasket scraper will dig the old filler out quick!
Mar 26, 2014 08:18 PM
redman84
22
Nov 15, 2011 01:26 PM
FordBlueHeart
Michigan Chapter
22
Sep 2, 2010 07:50 PM
felixr
22
Oct 11, 2007 08:13 AM
sancochojoe
Paint & Bodywork
Jan 29, 2004 08:40 PM
