Automatic hubs
Old Feb 27, 2004 | 05:07 PM
mrupert's Avatar
mrupert
Automatic hubs
The automatic hubs on my '96 Ranger (manual trans) are engaging on thier own during a slow speed turn, like turning from one residential street onto another. The truck is not in 4-wheel drive at the time. Any suggestions?
Old Feb 27, 2004 | 07:45 PM
wish it ran's Avatar
wish it ran
Re: Automatic hubs
Your hubs have a spring load. it sounds like your spring is broken causing it to slide into locked position when you turn.
Old Feb 27, 2004 | 09:10 PM
mrupert's Avatar
mrupert
Thanks for the feedback, but I don't see a spring in any of the repair schematics. Is it a non standard looking spring?
Old Feb 28, 2004 | 02:14 PM
wish it ran
No ,yours might just have a vaccum load . In that case check all hoses going in and out of wheel cylinder. im not reel sure if thats it but you should take a look .post up what kind of hub once u find out.
Old Feb 28, 2004 | 03:19 PM
mrupert's Avatar
mrupert
There's no vacuum line, I did find a small coil spring around the outside of the inner hub. It was intact and I found no broken or worn parts but alot of dried thick grease around all the parts. After a thorough cleaning, repacking and adjusting the wheel bearings, everything seems to be working fine. Thanks for your help.
