is this normal
Old Feb 27, 2004 | 05:03 PM
mybigredford's Avatar
mybigredford
is this normal
i just intalled a voltmeter guage in my truck and when i start the truck up, the guage reads around 12 or so for about 20 seconds and then it jumps to 14 and stays there, it does this everytime, so just wondering if this is normal or should it read 14 all the time?
Old Feb 27, 2004 | 05:25 PM
grizz_chaser's Avatar
grizz_chaser
I'm pretty sure this is normal, I think the reason is the alternator doesn't start charging immediately after start up. You may notice after first starting up in the dark that your head lights seem to get brighter after a minute or two because of the same reason. If I'm wrong I'm sure someone will come on and explain better. I hope this helps.
Old Feb 27, 2004 | 05:40 PM
pjrf350's Avatar
pjrf350
It,s normal. When the glow plugs stop there cycle thats when the voltage goes up to 14. Hope this helps
Old Feb 27, 2004 | 05:48 PM
grizz_chaser
See, I told you somebody would straighten me out. Thanks pj
Old Feb 27, 2004 | 05:50 PM
HeatStroked's Avatar
HeatStroked
Mine sits at 12VDC before and shortly after start up and maintains 14 - 14.6VDC when running.
Old Feb 27, 2004 | 06:07 PM
mybigredford
thanks for the help guys, im glad to have found FTE, i check it out eveyday, lot of info here, just hope you smart guys dont start charging shop rates on here. haha thought i would throw a funny in there.
later
Old Feb 27, 2004 | 10:02 PM
Vman1300's Avatar
Vman1300
You are right, cant beat this site for TONS of help!
BTW, my truck does the same as well, about a 20sec delay for the charge to increase.
Vman
