Disc brake swap
Old Feb 27, 2004 | 12:17 AM
mrwillie66's Avatar
mrwillie66
Disc brake swap
I have access to a mid 70's f250 with disc setup. I was wondering if I could use the caliper mounting brackets to install discs on my 66 f100. I'll also be using the steering gearbox, power brakes, and steering column.
Thanks
Rob
Old Feb 27, 2004 | 04:52 AM
banjopicker66's Avatar
banjopicker66
Mr Willie: You can find all sorts of details and specs on this very subjet here at FTE; just do a search, and it will surprise you how much is here!
Old Feb 27, 2004 | 05:17 AM
ddavidv's Avatar
ddavidv
Shortcut to the FTE how-to on my site: ddavidv's truck pages
Old Feb 27, 2004 | 11:18 AM
daveengelson's Avatar
daveengelson
There is also an article in FTE 'tech article' section. It is in the 1997 series.
Several months back I downloaded an article on the topic off one of the FTE forums. Until now, could not find its source. Thanx ddavidv.
I usually had to run search under http://www.mongrelmotorsports.homest...f100discs.html where the menu will include the ' Slick 60 " forum discussion on topic.
Anyhow, info obtained from FTE members/forum very helful in the disc swap on my 65. Also, suggest run search on subject 'power steering'.
Good luck,
dave
65 lwb,Custom styleside, 390, 3 speed o.d., pb
65, flareside, 302, 4speed, ps/pb
Old Feb 27, 2004 | 02:54 PM
garbz2's Avatar
garbz2
By using the mid 70s F250 calipers and spindle you will need to also use the eight lug hub....and the corresponding eight lug wheels. The F250 calipers are a totally different animal from the F100 with dual piston pucks and a very much larger pad.
Steering box, and collum will interchange to an F100.
Garbz
Old Feb 27, 2004 | 07:05 PM
FordBoypete's Avatar
FordBoypete
Cool OR.. .. .. ..!
Yebba yebba yeah but,
FWIW. ya can also use 77 up F150 Trailer Special HD Rotors which are same dimensionally as std F250, except 5 on 5 1/2 pattern rather than 8 lug usually found on F250s. That's what's on my 79 chassis under my 66 F100.
FBp
Old Feb 28, 2004 | 06:52 AM
garbz2's Avatar
garbz2
Pete
I have the same rotors on the front of my crew cab but it has the F150 calipers, not the dual puck F250.....79 Trailer Towing Special Chassis..will this rotors bearings and races be the same dimensionally? meaning the 5on 5.5 to match up to the F250 spindle?
Garbz
