what front gear?
Old Feb 26, 2004 | 10:37 PM
bigblack89's Avatar
bigblack89
what front gear?
what gears are in front diff or a stock 89 ford F150 with 351 ?
Old Feb 26, 2004 | 11:45 PM
wick246's Avatar
wick246
Could be 3.55, 3.73 or 4.10 but you have to check each truck to be sure. There is a tag on the drivers side door jamb which should tell you - you may have to do a search of this forum to find out how to decode the tag.
Old Feb 26, 2004 | 11:47 PM
bigblack89's Avatar
bigblack89
ok thanks what front end should i use a dana 60 or just build of what i have in there ?
Old Feb 26, 2004 | 11:52 PM
wick246's Avatar
wick246
Dana 60's are great - but most of us can't afford them. It depends on how hard you are going to drive the truck and what it will be used for. The Dana 44 IFS in it now is a good axle for standard 1/2 and 3/4 ton applications. I don't like the independant 44 for alignment reasons - some have converted to the straight Dana 44 and most seem to be very happy with the swap.
Old Feb 26, 2004 | 11:57 PM
bigblack89's Avatar
bigblack89
yea i will most likley stay with the dada 44 because its in it now will prolly put air lockers in it
