transmission swap
Old Feb 26, 2004 | 09:40 PM
runawayford's Avatar
runawayford
transmission swap
I have a 1996 f-250 with a 460 and a 5 speed manual. Is the new 6 speed interchangable with the old 5 speed. I'd like to put a 6 speed in my truck if it's possible.
Old Feb 26, 2004 | 11:48 PM
wick246's Avatar
wick246
I'm not sure though I thought the 6 speed was designed for diesel engines - the bell housing wouldn't bolt up.
Old Feb 28, 2004 | 01:02 AM
SoCalDesertRider's Avatar
SoCalDesertRider
Didn't the 460 and the diesel in those years use the same belhousing bolt pattern? I know the 351/302 used a different bolt pattern.
Old Feb 29, 2004 | 12:12 PM
bradyracing's Avatar
bradyracing
If you use a diesel trans on a 460 you will have no place to bolt your starter. The diesel bell doesn't have holes for the starter because the starter is bolted to the adapter plate on the diesel.
Old Feb 29, 2004 | 09:03 PM
SoCalDesertRider
Mmmm... OK. That clears that up!
RentAMan
Modular V8 (4.6L, 5.4L)
May 2, 2016 07:49 AM
urban87_cowboy
23
Jan 12, 2013 06:48 AM
2xford
Sep 22, 2011 09:40 PM
awhtx
Dec 10, 2010 10:23 AM
Dieselguy89
1997 - 2003 F150
May 3, 2008 08:28 AM
