limited slip for an 02 super crew
not very hard, the cost is the major factor, if you can find one used out of wrecked truck ,you can save some $$$$$, the benifits of a limited slip out weigh the cost. ive done some old rear end changes and it turned out well, i'm not uptodate on the newer rear diff's, i'm running a 3.73 Lts, not bad on milage, but i do alot of towing , if your lucky you'll find a whole axle,(check the tag)and change the whole assembly,and not worry about setting the gears(important).check the tag on the front axle for the ratio.
2x4
I have got a 2002 f-150 2x4 The axle code is U so this is the 3.55 rear differential, does anyone know the eaton part number for this type of upgrade, I don't know a whole lot about axle technology, but I do know some people who do. I would be able to get their help in the replacement procedure, but I just don't know which eaton posi-limited slip part is needed.
btw does the eaton have any improvements over the stock ford diff??
thanks,
//John
thanks,
//John
John-
The axle code for a 3.55 is not U. This is your trans code... a 4R70W. A 3.55 rear will be either an H9 for a factory limited slip or 19 for an open style under the axle block on your door jamb sticker. The site has a reader under the tech article section. All Ford axle codes are 2 digit codes. Double check your codes.
-Kerry
-Kerry
You can find gobs of used Ford 9.75 LS's on ebay, for super cheap.
Putting in a LS is not hard, but time consuming for the DIY'er, however I dont reccomend this for the weekend wrench turner.
I paid $40 for a 9.75'' Ford LS unit that came with spacers, ring and pinion and bearings (was from a 01 f150 wreck with 10k miles)
Prolly the most important item to have is a large shop vise and a large torque wrench.
The hardest part is swaping the ring gears from your open carrier to the LS carrier and removing the bolts, an impact wrench works best for this.
I put in my own LS in, with all new seals, (pinion too), oil, LS additive, shipping, etc, all came to about ~$150. But it took me about two 5-9 nights (i had got the wrong seals).
If you are really serious about doing this, I can post some directions to follow.
My mistake, I must have not taken my medication <evil grin> Anyway the u is my tranny, but axle code is 19 Thanks for all the information so as I see it I should find myself the 9.75 LS diff. After hearing that it takes the average gear head several hours to do this, I will probably take the parts to my mechanic and have him do it it'll be worth the 200 dollars considering it just took me 2 hours to change the spark plug wires on this thing. You practically need a phd to figure out that darn clip between the engine and firewall.
//John
//John
Need-a-cage
03-13-2010 01:54 PM
