Bronco II Ford Bronco II
fuel filter
Old Feb 26, 2004 | 05:52 PM
jjtopp52's Avatar
jjtopp52
Angry fuel filter
i am new to this site and have found it to be really helpful. i am having trouble getting the rock shield off that covers the fuel filter on a 86 bronco II, could someone explain what i may be doing wrong...man the filter is really hard to get to....thanxz for any and all help
Old Feb 26, 2004 | 07:17 PM
87 xlt named donk's Avatar
87 xlt named donk
Yes they are a pain but I guess it is beter that they are protected. There are two (10mm?) nuts that are on top of the frame that screw onto the posts welded on the shield. loosen the back about half and take the front all the way off. Pry the front of the shield down and pivot the stud out of the hole in the frame. It should give you just enough room to get the old out and put the new back. And you will only have to put the front nut back on. I know on mine I don't think I could get the back on if I took it off. Hope this helps...
Old Feb 27, 2004 | 12:19 PM
jjtopp52's Avatar
jjtopp52
87XLT
thankxz for the help...will give it a go this weekend.
Old Feb 27, 2004 | 01:43 PM
Sawfish's Avatar
Sawfish
Cool
It sounds like you guys are talking about the rear fuel filter. Do you know the Ford (or other) part number. Most catalogs list only thre front filter. I sure would like to have one in hand before I take mine off to see the part number.
Thanks
Old Feb 27, 2004 | 04:15 PM
87 xlt named donk
Its the front filter we are talking about.. Its right behing the drivers front fender well in the frame. Sorry I threw my box away last week. Good luck :-)
Old Feb 28, 2004 | 01:43 AM
87 XLT's Avatar
87 XLT
The rear canister is just a reservoir for the high pressure pump, theres no filter in there. Just change the one under the drivers seat on the frame rail
Old Feb 28, 2004 | 01:28 PM
JimmyJames's Avatar
JimmyJames
Don't need to remove bracket...
I just had mine done when I had a new tank installed.
The mechanic was able to change the filter without even removing the guard/bracket. He said it's really easy to do.
Old Feb 29, 2004 | 11:43 AM
Eric C.'s Avatar
Eric C.
I have a 86 and it only has the canister type on the frame rail. They are no problem to change as it just unsrews.
Old Mar 4, 2004 | 12:27 PM
jjtopp52's Avatar
jjtopp52
Cool
i tried it this weekend and still had a problem getting the shield off
i noticed jimmy james said it can be done without removing the shield...so what do you do just reach in...it seems very tight to do that and btw...thanxz to all who have responded
Old Mar 5, 2004 | 08:09 PM
LeonR's Avatar
LeonR
Filter
The front filter is a pain to get to. I have an 88 Bronco II and the only way i could get to mine was from underneath with limited space. The back canister i was told is a resevoir with a filter but blowing through mine I think not to east to blow through.
Besides its way to easy to get out for it to be very important and changed often.
Old Mar 5, 2004 | 08:17 PM
87 xlt named donk
I think Jimmy's mechanic beat his old filter out with a hammer and put in the wrong (smaller filter) in it's place if he thinks its easy. haha You did see and loosen the hose clamp holding the filter to the frame right jjtop2? It is hard and I would like to see someone do it without getting an armpit full of gas but if you just get in there you can do it. If not ya might think about Jimmy's mechanic... I would leave that back resevoir alone guys, I played with mine and ended up having to make a new gasket for it and there is no filter in there, so all was for naught...
Crewcab Turbo
Dec 27, 2012 07:59 AM
projectdagger
Aug 19, 2012 08:59 AM
jjurva
Jan 12, 2012 04:37 PM
wraysp
Jun 12, 2010 05:30 PM
JasonSmith
Modular V10 (6.8l)
Nov 2, 2005 10:37 AM
