Bronco II Ford Bronco II
Won't Start Intermittently
Old Feb 26, 2004 | 03:35 PM
B2Cool's Avatar
B2Cool
I have an 86 Bronco II. I have had the automatic transmission completely rebuilt and it is running great.
I have an intermittent problem where it will not start when the key is turned to the on position.
I have replaced the ingnition starter relay and replaced the battery. If I move the shifter, it may or may not start. If it doesn't then I have to jumpt the start truck using a jumper wire on the relay.
I have asked the shop that rebuilt the tranny and they said that it isn't the relay. The relay only costs $30.00 so I am just thinking if I should go ahead and replace it.
Any help would be appreciated.
Old Feb 26, 2004 | 04:37 PM
PJF's Avatar
PJF
Does it start if you put it in neutal?
It might be a bad park/neutal safty swith or the connector.
Old Feb 29, 2004 | 10:44 PM
B2Cool's Avatar
B2Cool
When I have the switch to the "on" position and move the shifter from park to neutral it may of may not start.
Some information I left off in my previous tread may help. The transmission is an A4LD and the engine is a 2.9 L 4x4.
Old Mar 1, 2004 | 10:46 AM
mrshorty's Avatar
mrshorty
How do the battery cables look? I've seen an intermittent not start caused by a bad connection at the battery cable, corroded cables, or even a bad connection at the starter.
Old Mar 1, 2004 | 01:51 PM
Ken00's Avatar
Ken00
Do you mean it doesn't crank at all or it cranks but won't run. If you have an intermitant no-crank condition chack for 12 volts at the small wire st the solenoid when you turn the key to start. If you don't have 12v then I would look at the safety switch, ingnition switch and wiring. If you do get 12v then look at the solenoid, battery, cables and starter.
Old Mar 2, 2004 | 09:00 AM
B2Cool's Avatar
B2Cool
The condition is all the dash lights come on and I can hear the fuel pump activate, however, the engine will not crank. I will check for the 12 volts.
Thanks.
Old Mar 2, 2004 | 09:01 AM
B2Cool's Avatar
B2Cool
I've checked the cables at the battery and have checked for continuity throgh the cable. I didn't look at the cables at the starter. Will also look into this.
WillFargo
17
Aug 16, 2012 09:00 PM
66 bronco roadster
1983 - 2012 Ranger & B-Series
Aug 9, 2012 08:29 AM
AlK
Apr 24, 2007 10:51 AM
JOHNJAY28
Oct 19, 2006 06:23 AM
latko
Oct 8, 2000 12:24 PM
