wiring diagram
Old Feb 26, 2004 | 02:14 PM
racer956's Avatar
racer956
wiring diagram
In trying to get my 4 wheel drive to work in testing the circuts I accedently keyed the neatrual side with 12 volt positive power. Blew out alarm power door locks windows int lamps. nothing worked. took a wire off the neatrual lead that I put the positive 12 volts trough and grounded it. Everything works normal. What did I fry to require a out of place ground. Can I download a wire diagram from the internet for the 4 wheel system. thanks in advance
Old Feb 26, 2004 | 09:32 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
It sounds like you might have cooked the GEM module.
Old Feb 27, 2004 | 03:43 AM
racer956's Avatar
racer956
gem modual
thanks for the reply thats what I thought but didnt want to belive it. Your the one who was talking about unplugging the waste gate valve for the turbo. Will that harm my truck and do I need to put in gauges. Also if thier is 12 volt continuos power to the waste gate cant break the line with and ondash switch to have the boost when wanted but to have the good fuel milelage when around town. I dont know just thought I would ask what do you think
