Modular V10 (6.8l)
Dies when trying to start
Old Feb 26, 2004 | 01:27 PM
txtimothyt's Avatar
txtimothyt
When I try to start my truck it will die . it seems to happen when it is damp or raining . I have a k&N air system. If i hold the gas down and keep the rpm at 2000 for about 30 sec then she will idle fine. Any one have any ideas ?
Old Feb 26, 2004 | 01:36 PM
Big Orn's Avatar
Big Orn
Welcome to FTE!
Go down a couple of topics and look under "Explain My Symptoms". See if this is your trouble.
If not, give a little more detail on the vehicle/engine: Year, mileage, any mods, etc.
Old Feb 26, 2004 | 02:22 PM
txtimothyt's Avatar
txtimothyt
It is a 2000 f250 with a V10 with 50K miles the only mod i have done is the k& n air system. It sounds like the same thing , but i didn't know since mine happens with moisture
Old Feb 26, 2004 | 03:12 PM
Big Orn's Avatar
Big Orn
Originally posted by txtimothyt
i have...the k& n air system.
When did you install it? Is there a chance you've oiled too heavily? It could be the MAF sensor - it's located downstream from your air filter.
When my truck did this it idled, but not smoothly. I had to replace the EGR.
I suppose you haven't had an SES (Service Engine) light come on? It still acts like the IAC, but I would first check the MAF sensor. It's fairly easy to take out and clean, but you must be careful not to apply too much pressure to that sensing wire - it's as thin as a hair. After you clean it, you may need to remove the positive cable from your battery for about 30 minutes or so and let the PCM (computer) reset.
Old Feb 26, 2004 | 03:26 PM
txtimothyt's Avatar
txtimothyt
Thanks for the help I will give it a try
Old Feb 26, 2004 | 10:33 PM
RSTX's Avatar
RSTX
IAC is my bet. My X did the same thing at about 55k miles. Only problem I've had with the engine. Can't complain.
Old Feb 28, 2004 | 04:53 PM
theswagg's Avatar
theswagg
It was the IAC on my '99. When started up cold it would stumble like crazy at idle. Warmed up it did okay while in park. If in gear sitting at a light it would try to shut off. The part is a pain in the neck to put in (putting in the lower bolt), but it cleared mine up right away. Seems after a while the air valve gets seized up and can't close off the air right. The engine light never came on for me, even though the book says after 50 starts a trouble code is supposed to light it up.
midd66
Jun 12, 2013 11:50 AM
rjride
Sep 21, 2011 10:19 AM
corey1981
Oct 10, 2007 10:13 PM
lost681
Jan 10, 2004 08:34 AM
