Modular V10 (6.8l)
Explain My Symptoms
Old Feb 25, 2004 | 10:09 PM
live2hunt's Avatar
live2hunt
Unhappy Explain My Symptoms
'99 F-350, V-10 of coarse, a little over 70K, live in Wyoming, K&N filter, no other mods. Recently it dies right after starting. It doesn't seem to be related to outdoor temp. Might be more likely to do it after truck has sat for a few hours/days. Took 6 starts this morning before it would stay running. I have pushed on the throttle once before and it would start then as well. But it doesn't do it every time.????????
Old Feb 25, 2004 | 10:15 PM
V10KLZZ71S's Avatar
V10KLZZ71S
I hate to do a sounds like,but it sounds like the iac [idle air control].They seem to stick sometimes messing up the air at idle.If it is this, it will probaly be ok at anything above idle,it just wont idle.Mine does it occasionally.
ps: dont over-oil the K+N filter,it will coat the mass air wire and cause problems.
Old Feb 26, 2004 | 08:59 AM
glcarpe's Avatar
glcarpe
If it will run by you helping with the gas pedal but refuses to idle or will idle but too low RMP, it sound like idle aur control to me also. I had exact same proble on my Windstar (3.8 L). To fix it, I took it off and clean the carbon out of plunger area with carb cleaner (careful not to let cleaner run into the solenoid area. I also sprayed a little lubricant inot solenoid area. Has been good as new since (about a month now). Very easy to do at least on the 3.8L.
Old Feb 26, 2004 | 09:37 AM
live2hunt's Avatar
live2hunt
Thanks for the responces!!
Just to reitterate the symptom: Engine sounds like it is going to run, but immediately dies after releaseing key in start possition.
I'll try finding and "cleaning" the IAC.
Old Feb 26, 2004 | 09:41 AM
V10KLZZ71S's Avatar
V10KLZZ71S
It is behind the throttle body plenum,hard to get to, looks like a silver round cannister, about 1.25 inches diameter.
Old Feb 26, 2004 | 11:27 AM
neilc88's Avatar
neilc88
Re: Explain My Symptoms
I feel this can be blamed on the K&N letting in too much dirt. I'm getting rid of mine soon.
Old Feb 26, 2004 | 12:51 PM
Monsta's Avatar
Monsta
Sit. Stay.
Here's the IAC
Old Feb 26, 2004 | 03:41 PM
live2hunt's Avatar
live2hunt
Excellent!! I do well with pictures!!!!!
My Haynes manual only shows where it is on a 5.4L.
This is the greatest site!
Thanks again.
Old Feb 26, 2004 | 06:59 PM
live2hunt's Avatar
live2hunt
MONSTA, Do you recomend the above "cleaning" proceedurew, or just buy another? I guess it's one of those situations where you don't know if it works 'till after the repair.
Old Feb 26, 2004 | 07:50 PM
Dwinn's Avatar
Dwinn
I had a similar problem and I think it was a fuel injection sensor. When I would start the truck it would die if I let off the gas. It would do this everytime. I would have to keep my foot on the gas and keep the engine running around 1,500 rpm. After about four or five minutes I would hear a faint swoosh sound and then the engine would run fine. Once it warmed up, starting and stopping the engine was fine. It only did it when it was cold.
Old Feb 26, 2004 | 08:31 PM
live2hunt's Avatar
live2hunt
Thanks Dwinn. I'll look into that. Wondewr if I should pay to have my engine "analyzed"?
Old Feb 26, 2004 | 08:57 PM
Monsta's Avatar
Monsta
Sit. Stay.
MONSTA, Do you recomend the above "cleaning" procedure, or just buy another? I guess it's one of those situations where you don't know if it works 'till after the repair.
I tend to try the inexpensive solutions first. If it doesn't work, then replace it.
Some have cleaned theirs and it didn't change anything until they replaced it altogether.
Old Aug 28, 2004 | 06:00 PM
elkhunter69's Avatar
elkhunter69
I'm having the same problem on the opening day of bowhunting season here in Colorado... All the anticipation and now I'm stuck at home, angry as can be...
live2hunt, did you happen to find a solution to your problem? I also have a K&N air filter on my F-350 V10. It will turn over fine, but then stalls immediately after it cranks...
What a bummer, I was all psyched to be up in the mountains...
Wyoming1975F2504x4
Jan 12, 2015 11:31 AM
SteveBricks
Wyoming Chapter
Oct 9, 2012 12:09 AM
wyoming4x4
Aug 6, 2009 06:01 PM
73f100shorty
Jun 27, 2007 04:51 PM
