1978 - 1996 Big Bronco
wiring question
Old Feb 25, 2004 | 06:10 PM
indysvodave's Avatar
indysvodave
wiring question
I'm an idiot when it comes to wiring... Give me an engine, and I can rebuild it, but give me a wiring diagram, and some wires, and I'll surely fry something!
Anyway, I was just trying to add some power outlets above my rear view mirror.
I spliced into the green wire to the dome light for a constant power source and drilled a hole and ran the other wire to a sheet metal screw for ground.
Should be simple enough right?
Well, I have everything back together, and the dome light and map lights work (there on the same fuse right?) but my outlets have no power. It didn't blow the fuse, so I know nothing is REALLY messed up...
Any ideas on what I might have done wrong? Should I run the ground wire to somewhere else?
I want a place to plug my radar detector in and not have the wire dangling down to the ash tray... Less conspicuos to cops, and thieves.
Edit, here's a link to my power sockets. Ignore the long screws, it was dark, getting cold, and I just wanted it up so it wasn't dangling by the wires. I need to find some shorter screws.
https://www.ford-trucks.com/user_gal...=36423&width=0
Old Feb 25, 2004 | 06:19 PM
lerandell's Avatar
lerandell
A test light comes in handy for stuff like this.
It does sound like you should look at your ground wire.
by using a cheap $1 test light you could tell if the power or the ground was the problem.
Old Feb 25, 2004 | 06:50 PM
indysvodave
I used a test light to find out which wire had constant power, and which was switched to the doors. I'll have to investigate further in the morning. I just wondered if maybe I should run the ground back to the dome light also.
Old Feb 25, 2004 | 07:02 PM
lerandell's Avatar
lerandell
That sounds like a good spot.
Old Feb 25, 2004 | 08:41 PM
ANdrewdrice's Avatar
ANdrewdrice
if you drilled a hole in the truck, did you strip the paint? you might not be making contineuity.
Old Feb 25, 2004 | 10:18 PM
BOJOFASO's Avatar
BOJOFASO
your dome light is switched through ground. did you meter your wires with the door open? if so both wires will be hot.it may sound stupid but just a thought. yes a 1 dollar test light is a very good investment.
