Holy vibration batman!!!
Old Feb 25, 2004 | 05:44 PM
Robw_z's Avatar
Robw_z
When I get my '72 F150 up to about 50mph, it suddenly begins to shake VIOLENTLY, the first time it happened I thought I was going to die. I feel the shaking mostly in the steering wheel. Once started the vibration doesn't quit until back down around 20mph. Whats going on here?
-Rob
Old Feb 25, 2004 | 06:14 PM
elemint's Avatar
elemint
Sounds like your drive shaft has a bad U joint. Might want to check out the truck too....
Old Feb 25, 2004 | 08:51 PM
gtex's Avatar
gtex
King Pins?
Old Feb 25, 2004 | 08:59 PM
78f3504x4's Avatar
78f3504x4
Was this a case of the feared "death wobble"?
Old Feb 25, 2004 | 10:26 PM
X-1's Avatar
X-1
Really bad steering joint, or u-joints, my joints were loose, and the whole truck had a constant vibration thru-out at around the same speed. Is your steering jerking you around side to side when you hit ruts, or potholes?
Old Feb 26, 2004 | 01:06 AM
Torque1st's Avatar
Torque1st
Posting Legend
Check out that front end!
Old Feb 26, 2004 | 10:50 AM
67and71_Carl's Avatar
67and71_Carl
Do you have two wheel drive or four wheel drive?
Old Feb 26, 2004 | 08:56 PM
averagef250's Avatar
averagef250
I had a truck that someone installed the wrong size pitman arm on (alittle loose). If you hit a pothole around 45-50 mph You'd lose any control over steering or brakes and usually run off the road. It sounded and felt like you were going to die.
Old Feb 27, 2004 | 02:50 PM
boogity24's Avatar
boogity24
i dont mean to be a smartass, but a 72 150??
Old Feb 28, 2004 | 12:55 AM
justdan's Avatar
justdan
bad front shocks did the same thing with mine. hope thats not too easy a solution
Old Feb 28, 2004 | 01:59 AM
gtex's Avatar
gtex
King Pins?
Old Feb 29, 2004 | 08:18 AM
bocephus_3349's Avatar
bocephus_3349
try the track bar bracket. if its loose then its like climbing on the old bull at a rodeo
Old Feb 29, 2004 | 12:13 PM
pro 69 ford's Avatar
pro 69 ford
check out your front end and maybe your drive shaft is outta' balance. it also can be your wheels are outta' balance , maybe you need some wheel weights?
Old Feb 29, 2004 | 12:24 PM
clohen's Avatar
clohen
For mine it was the king pins and a lotta work.
Old Feb 29, 2004 | 06:09 PM
TomThrall's Avatar
TomThrall
Sounds like a tire that is badly out of balance, with poor shocks. Is the tread cupped or worn ?
