Distributor Help
Old Feb 25, 2004 | 05:42 PM
Coogles's Avatar
Coogles
Distributor Help
I got an msd distributor for my 460. Is it compatible with the TFI module? Does the TFI system have anything to do with the fuel injector timing?
Old Feb 25, 2004 | 05:57 PM
Coogles's Avatar
Coogles
Ive been doing a lot of reading and it just seems that the TFI distributor is only different in means of advancement. It doesnt have any vaccume or cyntrifugal advance, so it uses a coil instead. Thats why Im assuming it has 20 wires coming out of it.
The distributor I have has 2 wires coming out of it, one to the ignition and the other for ground.
Im not sure though if it has its own crankshaft posision sensor, or if the fuel injector timing comes from the distributor.
Anyone know?
Old Feb 25, 2004 | 06:50 PM
EPNCSU2006's Avatar
EPNCSU2006
Fuel injection gets its timing information from the TFI. If it's integrated into the distributor, you'll need a distributor that has the TFI built in, or somehow rig up a remote mount for the TFI, and wire it to work with an aftermarket distributor.
Old Feb 25, 2004 | 07:15 PM
Coogles's Avatar
Coogles
I read in the chilton manual that it has a crank sensor which feeds info to the computer on injector timing. I also read that the tfi model is only a better method of spark advancement.
It says there is a crank sensor, is there?
Old Feb 25, 2004 | 08:32 PM
EPNCSU2006's Avatar
EPNCSU2006
I don't know there to be a crank position sensor, although I'm not very familiar with a 460. The computer gets all timing information from the distributor (TFI) as far as I know. The computer controls all timing advance on engines with TFI Ignition systems.
Old Feb 25, 2004 | 08:36 PM
Coogles's Avatar
Coogles
does anyone know if I can hook up a crank sensor or some other timing method besides the tfi distributor?
Otherwise I cant seen to find any high performance distributors with TFI. I need to get fuel injection working
I read a lot in the manual about the TFI and all it explained was how it advances the timing. How it goes to the TFI box and the EEC
But for fuel injector timing was under the crank sensor page.
Old Feb 25, 2004 | 10:19 PM
Coogles's Avatar
Coogles
are you sure the 460 injector timing comes from the tfi distributor? Someone please tell me if it comes from the distributor or crank sensor.
