Casting # for 4V heads
Old Feb 25, 2004 | 05:04 PM
bigwheelin's Avatar
bigwheelin
Does anybody know what the casting # for 1987 351 windsor 4 barrel heads should be? Or are these just the same heads as all the other late model heads, and Ford just put a 4 barrel on top
Latter
Bob
Old Feb 25, 2004 | 09:18 PM
daerhldgs2's Avatar
daerhldgs2
thought Ford had gone to fool inj. by then, otherwise I think they're the same heads.
Old Feb 26, 2004 | 07:56 AM
jwtaylor's Avatar
jwtaylor
My 87 351w has E5TE's, which is identical to the E7TE, except the E5 has larger combustion chambers and a larger thermactor bump. If your asking this in order to get a set of heads, go with the E7TE, as the smaller combustion chamber will bump the compression, actually if your starting fresh, the gt-40 / gt-40p or D0OE heads would be better, IMO, as a starting point.
In 87 the 351w was still carbed. later
Old Feb 26, 2004 | 11:34 AM
f1001978's Avatar
f1001978
The only "4v" heads for a windsor are C8OE which are 68 302 heads. They have 4v cast into them.
http://www.nvsaac.com/shelbyparts/heads.htm
Old Feb 26, 2004 | 02:25 PM
jwtaylor's Avatar
jwtaylor
All the 302/351w heads are about the same, no dramatic difference compared to the cleveland 2v and 4v.
